This is my entry for the "Last Year of the Panavia Tornado" comp. I don't usually build aircraft, but needed something other than armored vehicles to do, so I thought I would give this a shot. I will be using the Revel kit and showing it in flight over the dessert.Nemesis attached the following image(s):
Great to see another entry and good luck with the build
Great idea Nem  will look forward to seeing it progress. Al
I look forward to seeing this progress. Mark Regards Markwarren (Mark) Admin
Good luck Nem, look forward to seeing your progress. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Great to see another Gulf War Tornado build. good luck with the comp
Thanks for looking in and your comments everyone, have a cool idea for the base, just hope it comes out as I see it in my head!
 Good luck in the comp and nice kit Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Good luck with the comp Nem, am sure you'll do this kit justice.... Regards Alan
Thank you Andy and Alan, hopefully I can pull of my idea and do it justice.
 Good choice and have fun building your pinky Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Good to see your kit has arrived, but I fear it may be you being moved out to the shed. Good luck with your entry. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
If you know my ways of building then you will not be surprised that I have started by not following the instructions, by-passed the ejector seats and gone straight to the cockpit tub and front fuselage! Reasons for this are it will be easier to mask off the cockpit when painting the full fuselage, its easy to add the seats last. Everything is dry fitted at the moment so I can see how well the front halves fit and adjust where needed to get the best fit without lots of filler and sanding. Next up will be priming all the parts. Nemesis attached the following image(s):
The fit looks pretty good from your pics Nem. Good luck with the build. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Nice start and looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good Nem, I'm installing the seats last too. Makes masking off easier later. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Off to a good start, looking good. Mark Regards Markwarren (Mark) Admin
Nice start Daran and totally agree regards leaving the 'bang seats' out until later, much easier that way.
Is that a raised panel line I can see on the side of the nose, below the cockpit?
Kev  Per Ardua Ad Astra
Its a location line for the in flight refueling arm assembly to fit, once in place the line is not noticable. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (36)
