9 Pages <1234>»
Magpie1832's Tornado Gr.1 "Operation Desert Storm " Options
#21 Posted : 24 November 2018 01:41:17
BigGrin Nice start and looking good, by the way most plastic/resin kit parts have a release agent that needs to be washed in warm soapy water to remove it before construction begins its the same with etch parts but they have an oil coating that will need the use of a degreaser so the glue and paint will adhere to themCool
Thanks Andy.
Thank you all for looking in and nice comments.
Chris
#22 Posted : 25 November 2018 01:25:27
Did a little painting of the cockpit today.
Firstly I went to the nearest Modelshop to me an hours drive to Widnes Models. Wow what a model shop. Got my Vallejo Air paints for this build.
I had to try and decide which colours to buy and colour match as Revell are sooo bad with there colours. They don't give any crossover or you have to mix half the colours to get the right shade.
I highlighted the switches and painted the MFDs. And gave them a light panel wash. Looks ok ish to me.
Excuse the the floor shade its a little light needs a darker shade.
Chris
Cool Cool
magpie1832 attached the following image(s):
#23 Posted : 25 November 2018 12:47:58
That is looking good, very busy in there! Cool
DaDokta
#24 Posted : 26 November 2018 10:38:47
Looking great!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Kev the Modeller
#25 Posted : 26 November 2018 12:06:37
A nice start on the cockpit Chris, I like the look of the green computer screens, very realistic - well done. ThumpUp
Per Ardua Ad Astra
#26 Posted : 26 November 2018 22:54:08
#27 Posted : 27 November 2018 01:26:28
Thanks For looking in guys and your nice comments.
Thanks Nem, will look at those.
I have spent the evening adding wiring and a couple of photo etch parts (lots of filing and shaping) of bad made and fitting bits.
Here are the latest pics.
Chris
#28 Posted : 27 November 2018 04:43:49
Some great details going into the cockpit Chris Cool very nice.
#29 Posted : 27 November 2018 09:18:56
Very nice work Chris, the detailing is really coming along beautifully.....Cool Cool
DaDokta
#30 Posted : 27 November 2018 11:39:19
The wiring looks great!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#31 Posted : 27 November 2018 12:54:08
Looking good Chris, the addition of the wiring is a great idea.
Kev the Modeller
#32 Posted : 27 November 2018 21:10:32
Some nice added details going into your build Chris and looking good - well done. ThumpUp
Per Ardua Ad Astra
#33 Posted : 28 November 2018 00:54:09
Thanks for looking in guys and your nice comments Cool
Tonight I painted the screens and the wiring, added a few scratch details that aren't in the kit or PE. Then gave it a dirty wash with some light grey then Tan.
Chris
#34 Posted : 05 December 2018 00:10:11
Not done too much over the last few days.
I started by removing one of the hatches on the fuselage to add the Avionics bay. I made it from plasticard.
I then dry fitted the rear fuselage sections and added panel lines that are missing. Also added some location tabs on the inside to get the sides to sit properly. I glued the rear wheel bays in place.
I also added the weights in the front. I got some wheel weights from work and stuck them in place.
I've added the fuel probe to the front section, fit was ok.
I then moved onto the wings and removed the flaps and leading edges ready for the PE.
Chris
Cool Cool
#35 Posted : 05 December 2018 01:43:37
Looking good. Cool Cool
I used those self adhesive weights for the Antonov build as counter balance and they work a treat. Went into a local tyre shop to buy some and when the chap new what they were for he gave them to me for free. What a nice guy. BigGrin
Keep up the good work.
#36 Posted : 05 December 2018 09:04:28
Looking good Chris, some excellent work.BigGrin Cool
#37 Posted : 05 December 2018 19:22:54
Cheers guys for looking in and your comments 😎😎
#38 Posted : 05 December 2018 19:36:47
Very nice update Chris, coming along very nicely indeed....Cool Cool Cool
#39 Posted : 05 December 2018 20:22:35
Lovelywork Chris, taking shape very nicely.Love Drool
Kev the Modeller
#40 Posted : 05 December 2018 21:36:33
Another nice update Chris and making good progress with your build. Well done. ThumpUp
Per Ardua Ad Astra
Guest (21)
9 Pages <1234>»
This page was generated in 0.119 seconds.
