7 Pages <1234>»
Nems Gulf War Tornado in flight. Options
Kev the Modeller
#21 Posted : 30 November 2018 20:03:25
Its a location line for the in flight refueling arm assembly to fit, once in place the line is not noticable.
Oh ok, that makes sense now. Thanks for the insight Andy. ThumpUp
Per Ardua Ad Astra
#22 Posted : 30 November 2018 21:19:34
It is an option on this kit to have the re-fueling arm retracted or extended, you have to drill out some holes depending on which option you want.BigGrin
#23 Posted : 30 November 2018 22:28:22
So on the above note I took the time to look through the destructions to see how the refueling arm fits. I looked for the holes I needed to drill out and they are, how shall we say, a bit hit and miss! So I cut the pins off the arm mount and did it my way. The arm mount is a lousy fit so I glued it in sections, flowing ultra thin glue down the seam. Luckily there is an outline of where it fits so I had something to go by.Blink BigGrin
#24 Posted : 03 December 2018 09:11:09
So while I wait for the primer to dry on the cockpit parts I made up the wings, and tail components and the weapons pylons, then dry fitted all the parts with the main fuselage. They will all need some work as they are not the best fit!Crying But on the whole not a bad looking kit.BigGrin Cool
The pylons should have been fitted and allowed to swivel, but they do not follow the contour of the wings very well, and as I am showing it in flight they will be glued in place as will the wings and tail which should also move but are a poor fit to the contour of the fuselage.
#25 Posted : 03 December 2018 17:56:13
That's a big model, should look impressive Cool
Kev the Modeller
#26 Posted : 03 December 2018 21:12:01
Yep, sure looks big! Blink Nice work so far Daran - well done. ThumpUp
Per Ardua Ad Astra
#27 Posted : 03 December 2018 21:17:30
I really did underestimate the size, base is gonna be huge!!LOL BigGrin
So on with the show!BigGrin I have finished the wings and tail, all gaps and seams are gone. The swing wing works but only until the fuselage is seam free, then they will be permanently fixed in place as will the tail and the weapons pylons. The cockpit tub has had its primary colours sprayed, refueling pylon is fitted and the intake fans have been painted. Next step will be the intake fan surround and then I can glue the 2 halves of the main fuselage together and tackle the seam line. Once the cockpit is dry it will get a coat of clear and then decals and detailing.
#28 Posted : 03 December 2018 21:27:16
Great kit, wow that’s big. I hope you’ve got enough room for a hanger in you garden for that.LOL
Great start, will be watching with interest.
#29 Posted : 04 December 2018 00:02:41
Making great progress Nem, certainly going to be a beast of model to display..Cool Cool
#30 Posted : 04 December 2018 00:20:27
Nice work Nem, Looking good.
Chris
#31 Posted : 04 December 2018 09:17:45
Good luck with your build Nem.
Trev
Kev the Modeller
#32 Posted : 05 December 2018 21:38:05
Nice work as always Daran, looking good and certainly forging ahead with your build. Well done. ThumpUp
Per Ardua Ad Astra
#33 Posted : 06 December 2018 21:05:19
Thanks all for looking in and your comments.BigGrin
Intake fan blades are finished and fitted and the 2 halves of the main fuselage have been glued together. Once they have dried I will tackle the seams which are not as bad as I first thought. While I was there I dry assembled the main parts, this thing is huge!Blink Blink LOL Cool
#34 Posted : 06 December 2018 21:48:34
It's certainly large, great job so far, looking good.
Kev the Modeller
#35 Posted : 06 December 2018 21:55:25
Certainly is a whopper Daran. Think you'll need to build a hangar in the garden for it mate, can't see your lovely lady allowing that to stay indoors. BigGrin
Per Ardua Ad Astra
#36 Posted : 06 December 2018 23:00:28
Thank you for the kind comments.BigGrin Cool
Started adding detail to the cockpit and controls.BigGrin
#37 Posted : 07 December 2018 00:22:21
Nice update Nem. Cockpit looks great. ThumpUp
Chris
#38 Posted : 07 December 2018 09:13:29
Lovely work, looking excellent.Love
Sticky Wickett
#39 Posted : 07 December 2018 13:44:18
Nice detailing in the cockpit Nem. Coming along a treat.
Phil W.
#40 Posted : 07 December 2018 16:38:58
Thanks for looking in and your comments everyone.BigGrin
Whilst waiting for other parts to dry I got on with the engine exhausts and laid the base colours down. Once dry I can get on with some detailing. Great thing with this assembly is it can be fitted after the main fuselage has been painted to save on masking!Cool BigGrin
Guest (22)
7 Pages <1234>»
This page was generated in 0.277 seconds.
