Well the cockpit is 99.9% finished and now fitted into the front half of the fuselage. It had a couple of coats of Klear to seal in the decals and once that was dry I used a flat steel dry brushed on and then a black wash to pick out some details. Once this had dried I gave it a couple of coats of matt varnish and once that had dried I used Klear on all of the dial lenses and screens. Some additional weathering will be done on the final paint stage of the whole Tornado. Next up will be to tackle all of the seams on the front and rear fuselage and re-scribe some panel lines. Nemesis attached the following image(s):
Looks great Nem. Them decals look great. I chose to paint mine but don't look as good as using decals. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Nice work on the cockpit
 Looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thank you all for looking in and your comments, the decals for the cockpit took micro set and micro sol to get them to look ok, they were quite thick. I have 90% finished the engine exhausts now with all the base colours and some dry brushing, I am awaiting the desert pink for the sides to be painted and some more weathering and detailing will be done at final assembly. Nemesis attached the following image(s):
 All looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
I've yet to order my pink. Didn't find this branded one will look later. Chris. On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Tried out the Desert Pink, its an enamel airbrush ready paint and it was a pleasure to use, usual standard from Alclad. Exhausts are done with some tweaking and detailing on final assembly. Nemesis attached the following image(s):
Looking well. Only sprayed enamel once for the red hull of the Hood. It was very dusty finish . Obviously didn't do it correctly lol. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hi all looking good ,look forward to following ,cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,421 Points: 22,573 Location: Northamptonshire, England
Look excellent, nice work. Mark Regards Markwarren (Mark) Admin
Those seats look great, I think they're the ones I have on order for mine. I also got hold of the Alcad paint. Looking forward to seeing more updates.
Just a small update during the madness called Christmas and New Year, the Quickboost seats have been trimmed off the casting blocks and a dry test fit to check the clearance to the canopy. Nemesis attached the following image(s):
Nicely coming together
