. Hi Guys, I started this build man many years ago. I had done most of the seat and primed a few parts.
I have now added the ejector handles and sprayed up the seat pads. I yet have to paint the gas bottle on the side of the seat.
I also re-sprayed the tub and the instrument panels in a different grey as I don't know which paint I had used previously.
So this is where Im up to on this one.
Chris
magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Now that is a cracking kit,looking forward to seeing this come together!
 A blast from the past there but looks good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Ooow Chris now that looks really interesting Can’t wait to see what you do with her Regards Gray
Nice looking display model, would look great alongside Italeri’s new 1/32 F-104 Starfighter https://www.italeri.com/en/prodotto/2738/1/1000
Cheers guys for the nice comments.
I have spent a little time on the switches etc. Not really much to say on this part.
Chrismagpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Looking very nice Chris. Mark Regards Markwarren (Mark) Admin
Very nice work, love the way the detail is turning out.... Regards Alan
Looks fantastic, nicely done with the dry brushing!
Great job so far Chris  very realistic. Al
Thank you so much for the comments guys.
I have spent a few hours today doing some more. I have made the Head up display, panted it and dry brushed. I also did the lower of the main panel, painted and fitted it. Plus painted the gas bottle on the seat.
I placed the seat in position just to see how it looked.
Chris 😎 magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Finally finished her.
I installed all the seat belts and put all dials on. I first gave it a few coats of Pledge then a quick wash. I then put the decals in place and gave it a semi coat.
I built the rest of the instrument panel and glued the seat in place.
Chris magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Guest (11)
