80 Pages «<2930313233>»
Sticky Wickett
#601 Posted : 04 January 2019 09:38:11
I then fitted an eyelet as supplied with the part-works. A 0.55mm diameter hole had to be drilled 10mm from the top of the fairing as per the instructions.
The attached photo shows the marking out for the hole being checked with vernier calipers.
Sticky Wickett
#602 Posted : 04 January 2019 09:39:15
Eyelet fitted.
Sticky Wickett
#603 Posted : 04 January 2019 09:40:31
Another part-works supplied piece of etched brass was folded as per the instructions and fitted in place.
Sticky Wickett
#604 Posted : 04 January 2019 09:43:33
That concludes this weeks update. More to follow next week.
Thanks for looking in and your comments, have a great weekend and happy modelling!
Phil W.
#605 Posted : 04 January 2019 10:29:52
Precise as always.... looks great...Cool Cool
Sticky Wickett
#606 Posted : 04 January 2019 10:55:05
Thank you Alan. The conning tower will really start to take shape during the next month or so. I'm hoping to have it all complete by early March.
Phil.
#607 Posted : 05 January 2019 11:07:10
Just catching up with the latest, some very fine detail being applied. Excellent work as usual.Love
Sticky Wickett
#608 Posted : 07 January 2019 11:54:19
Thank you Mark! Lots of progress in the pipeline for 2019!
Phil W.
Kev the Modeller
#609 Posted : 07 January 2019 12:50:11
Nice work as usual Phil, I'm really looking forward to seeing the finished model later this year. Drool ThumpUp
Per Ardua Ad Astra
Sticky Wickett
#610 Posted : 07 January 2019 17:27:21
Thank you Kev. Fingers crossed i'll complete the model this year, but i have a ton of scratch building to do on it and these things always take a little longer than expected.
Phil W.
Sticky Wickett
#611 Posted : 09 January 2019 23:28:43
More progress this week on the conning tower; fitting part-works supplied PE.
The first job was to prepare the two sections of treadplate that make up the decking on the bridge.
I had to remove a segment from the larger section so that it would fit within the modified shape of the bridge.
Sticky Wickett
#612 Posted : 09 January 2019 23:30:45
Treadplate fitted.
Sticky Wickett
#613 Posted : 09 January 2019 23:32:33
The next job was to glue the etched brass dial to the binnacle.
Sticky Wickett
#614 Posted : 09 January 2019 23:34:43
Two layers of PE, one with treadplate, were sanded, prepped and glued together. This section fits around the binnacle.
Sticky Wickett
#615 Posted : 09 January 2019 23:35:30
The binnacle and treadplate section fitted to the bridge.
Sticky Wickett
#616 Posted : 09 January 2019 23:40:03
More PE fitted; this time a foot rest made up of two curved sections, one with tread plate. Both sections were prepped, glued then filed to fit correctly. I also fabricated a small length of 0.5mm wide plastic strip to act as extra support underneath the foot rest.
Sticky Wickett
#617 Posted : 09 January 2019 23:46:54
I then fitted a similar foot rest to the port side of the bridge along with a small PE section, bent at each end as seen in the attached photo.
Sticky Wickett
#618 Posted : 09 January 2019 23:48:20
A further, smaller piece of PE was bent to shape.
Sticky Wickett
#619 Posted : 09 January 2019 23:49:24
This was then glued in place as seen in the attached photo.
Sticky Wickett
#620 Posted : 09 January 2019 23:51:57
That concludes this update with more part-works supplied details being added next week.Cool
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
This page was generated in 0.148 seconds.
