Joined: 29/01/2019 Posts: 6 Points: 18 Location: Australia
Hi all, from Downunder, I'm building R2D2, quite impressed so far. Build with care checking document. Australia seems last to know of this project. Aus. & NZ sites now don't exist. Waiting for Issue39 at present. Available weekly, from a newsagent. There may be a problem I found with ISSUE37, lightsabre ejector motor. I checked small gear on the motor to see if it turns freely. It won't move at all.  . I tried with care. I am unsure if it is just a normal motor (reversible) or something special. Please advise if a dud and how to get it replaced. Regards, Kinchar
 Rank: Pro  Groups: Registered
Joined: 23/12/2018 Posts: 318 Points: 949 Location: Illinois, USA
Welcome to the forums Kinchar Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,421 Points: 22,573 Location: Northamptonshire, England
Kinchar wrote:There may be a problem I found with ISSUE37, lightsabre ejector motor. I checked small gear on the motor to see if it turns freely. It won't move at all.  . I tried with care. I am unsure if it is just a normal motor (reversible) or something special. Please advise if a dud and how to get it replaced. Hi Kinchar Welcome to the forum. The light saber operation is tested in issue 53 along with the leg sensors. At this point you can order replacements if needed.Should you require a replacement then you will need to request that via your newsagent. Regards Mark Regards Markwarren (Mark) Admin
