Joined: 20/12/2018 Posts: 10 Points: 33 Location: Banbury
I bought the official power supply for the Falcon, with the idea that I could leave the LEDs on for some time as a feature in the room. However, after a few hours of this, when I turned them on the following day the rear engine lights and the front spots were very dim. The ramp and cockpit lights were fine.
I got hold of a replacement MCU, fitted this, and everything was fine again, until the same thing happened again. I have now replaced the MCU board again, and all is good.
Question is, is the MCU a bit rubbish, and not capable of running the lights over an extended period, or could there be another problem?
Cheers!
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,421 Points: 22,573 Location: Northamptonshire, England
It depends on how long you were keeping them on for, or whether you have any additional lighting attached beyond the build specifications. The msu is probably not designed for use as ambient lighting for a length of time. In normal use I have seen no issues. If you wish to use the engine lighting for some considerable time, you may think about using a separate board that will allow it to be displayed as a lighting effect on a permanent basis. Regards Mark Regards Markwarren (Mark) Admin
Joined: 28/01/2016 Posts: 171 Points: 503 Location: Adelaide, Australia
The MCU is a discrete component, just a computer, ones and zeroes. That is, it will work or it won’t. The dimming of lights would be associated with the output from the power pack decreasing as the heat inside the power pack heats up. Maybe try and source a power pack with a slightly higher current output. I run an extra 12 leds on my Falcon, all wired into the mcu combined with a 1700mA 15.3 watt power pack output. I actually calculated the wattage/ ampage requirement according to total / type led usage. Running Falcon for two consecutive 8 hour days at a model comp caused no issues. FYI - if you add more leds and suck more power thru the mcu, this can, over time, cause the mcu to fail, as it is designed to a spec. It’s a bit like modifying an engine to squeeze more horsepower out. Yes it can be done, but engine life will be shortened. BUILDING: Taking a break / Waiting for the next epic build to be released
COMPLETED: Hachette Spitfire, Hachette Bismarck, Deagostini Millennium Falcon, Deagostini R2-D2
Thanks for the replies!
I don’t have any additional lights running off it.
If the power supply was getting overheated, wouldn’t leaving everything off for a while correct the problem? If so, it didn’t. It basically created a permanent issue. Only replacing the MCU corrected it.
Saying that, would be interested in trying a different power supply. Can you recommend one with said higher current output?
This is what i’m Using. Ebay purchase. BUILDING: Taking a break / Waiting for the next epic build to be released
Great advice. Thanks. Problem solved by ordering and now using a 9v switching power supply with 1200mA output as compared to the official supply's 1000mA. Works a treat.
