80 Pages «<3738394041>»
Sticky Wickett
#761 Posted : 08 March 2019 00:55:46
I then made up a control lever rod from 0.5mm diameter brass rod and 0.8mm diameter tubing.
Sticky Wickett
#762 Posted : 08 March 2019 00:56:28
This photo shows where the control lever and rod will be positioned.
Sticky Wickett
#763 Posted : 08 March 2019 00:57:54
Lever and rod in place.
Sticky Wickett
#764 Posted : 08 March 2019 00:58:28
The third control surface handwheel fitted.
Sticky Wickett
#765 Posted : 08 March 2019 01:00:25
From above.
Sticky Wickett
#766 Posted : 08 March 2019 01:04:29
I then temporarily fitted the gun barrel to the body, just to see how it looks so far!BigGrin I made a locating pin from 1.0mm diameter rod, cut to length to hold the gun in place. Works a treat!
Sticky Wickett
#767 Posted : 08 March 2019 01:05:34
From another angle.
Sticky Wickett
#768 Posted : 08 March 2019 01:06:38
A view looking from the other side.
Sticky Wickett
#769 Posted : 08 March 2019 01:08:24
That concludes this post with more updates next week on detailing this Flak 37 gun.
Thanks for looking in, have a great weekend and happy modelling!BigGrin Cool
Phil W.
#770 Posted : 08 March 2019 09:01:45
Another great update Phil. Stunning work.Love
Sticky Wickett
#771 Posted : 08 March 2019 15:06:30
Thanks Mark!!!!BigGrin
Phil W.
#772 Posted : 09 March 2019 09:45:54
Stunning.... a great example of scratch building.....Drool Drool Drool
#773 Posted : 09 March 2019 12:22:39
Great work Phil. Looking really good
Chris
Sticky Wickett
#774 Posted : 13 March 2019 11:16:43
Thank you Alan!BigGrin
Phil W.
Sticky Wickett
#775 Posted : 13 March 2019 11:17:10
Chris
Thank you very much Chris!Cool
Phil W.
DaDokta
#776 Posted : 13 March 2019 13:07:31
Awesome detailing as always! Wow!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Sticky Wickett
#777 Posted : 14 March 2019 23:52:25
Thank you very much Walter!BigGrin
Phil W.
Sticky Wickett
#778 Posted : 14 March 2019 23:56:27
This weeks update sees more detailed additions to the Flak 37 gun that will be located on the conning tower lower deck.
I concentrated on a cluster of levers and rods situated on the right hand side of the gun body.
The attached photo shows one of the small components i made using round rod and square strip with a small length of 0.5mm diameter brass rod, bent to shape.
Sticky Wickett
#779 Posted : 14 March 2019 23:57:32
The brass rod in this photo points to where this small component is located.
Sticky Wickett
#780 Posted : 14 March 2019 23:58:25
A close up photo.
This page was generated in 0.150 seconds.
