Always a pleasure to help you John if possible.... Regards Alan
Joined: 25/04/2014 Posts: 374 Points: 1,134 Location: Mandurah W.Australia
Hi Everyone I'm currently working on Issue 119 ( dressing the Spars )...and I have a couple of query's. The Lateen sail spar V14 on the large plan from Issue 113 shows 8 lift ropes at 6mm equal spacing. The installation Issue 130 shows only 4 lift ropes at 8mm spacing. Which instruction is correct? Also the large plan shows spar V14 with a loop in the centre and I can't work out the purpose of it. Advice would be most appreciated... Regards JohnP
John Passmore wrote:Hi Everyone I'm currently working on Issue 119 ( dressing the Spars )...and I have a couple of query's. The Lateen sail spar V14 on the large plan from Issue 113 shows 8 lift ropes at 6mm equal spacing. The installation Issue 130 shows only 4 lift ropes at 8mm spacing. Which instruction is correct? Also the large plan shows spar V14 with a loop in the centre and I can't work out the purpose of it. Advice would be most appreciated... Regards JohnP Hi John, Had a look at this one. Regarding the lift ropes, you should continue with what it says within the instructions for issue 130 and the Official build diary, not the mast plan. 4 lift ropes, 8mm spacing. As for the loop on the spar, I think the loop is there purely for visual purposes only. Just use the 1m long line as outlined in the instructions. Hope this helps. Regards Alan
Gandale wrote:John Passmore wrote:Hi Everyone I'm currently working on Issue 119 ( dressing the Spars )...and I have a couple of query's. The Lateen sail spar V14 on the large plan from Issue 113 shows 8 lift ropes at 6mm equal spacing. The installation Issue 130 shows only 4 lift ropes at 8mm spacing. Which instruction is correct? Also the large plan shows spar V14 with a loop in the centre and I can't work out the purpose of it. Advice would be most appreciated... Regards JohnP Hi John, Had a look at this one. Regarding the lift ropes, you should continue with what it says within the instructions for issue 130 and the Official build diary, not the mast plan. 4 lift ropes, 8mm spacing. As for the loop on the spar, I think the loop is there purely for visual purposes only. Just use the 1m long line as outlined in the instructions. Hope this helps. Regards Alan Thanks for your help Alan, much appreciated... Regards JohnP
Hi Everyone Progress to March 2019: Issues 119 and 123 refer: * Dressed all spars and included foot ropes which are not called up. Found details in Mr Gandale's excellent diary ( Page 154 Post 3074),thanks a lot Alan...it was a great help... * Fitted Crosstrees and flagpoles. * Fitted remaining Stays... Regards to all JohnP John Passmore attached the following image(s):
Excellent progress John, she looks amazing..... Regards Alan
Very nice work John, looks stunning. Mark Regards Markwarren (Mark) Admin
Amazing build! Greetings, Walter
Gandale wrote:Excellent progress John, she looks amazing..... Regards Alan Thanks for the nice compliment Alan... It's getting a bit hard now, innit?... Regards JohnP
Markwarren wrote:Very nice work John, looks stunning.
Mark Hi Mark Thanks for looking in and the nice comment... Getting into the hard part now - the dreaded rigging - and had a few mishaps already as I have to figure out how to do things. So a lot of trial and error going on!.... Regards JohnP
DaDokta wrote:Amazing build! Hi Walter Thanks for the compliment... Regards JohnP
Hi Everyone A little progress for April 2019 herewith... * Fitted Backstays to Foremast, Mainmast and Mizzenmast... * Fitted Mainsail - haven't decided yet on how to present it... * Had to modify the mainsail halyard leading over the cap, as I hadn't drilled holes in the little square bit...  So I fitted 2 little guides for the halyards to stop them sliding off the cap...  Doesn't look toooo bad!!!... Regards JohnP John Passmore attached the following image(s):
Hi John, she just looks better and better.... Rigging does get a little tricky in places and needs some care. Judging by the looks of your build I'd say you're getting through it all beautifully.... Very well done..... Regards Alan
Gandale wrote:Hi John, she just looks better and better.... Rigging does get a little tricky in places and needs some care. Judging by the looks of your build I'd say you're getting through it all beautifully.... Very well done..... Regards Alan Hi Alan Thanks for the nice compliment. Yes - it is getting a bit tricky now, had a few accidents already. Posting an update in a minnit - if I can remember how to do it - been so long for this old codger.... Kind regards JohnP
Hi Everyone, Been a while but I've been moving along a bit, so update follows... Issues 124 to 128 refer: Fitted sails and running rigging to Main and Foremast...  Not as good as some efforts here, but I'm happy.... Fitted extra cannonball crates to both quarter decks.... Regards JohnP John Passmore attached the following image(s):
 Very nicely done she is starting to look the biz Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
John That looks wonderful. Your hard work has really paid off with a nice model. Tony Happy Modelling
Beautiful John, you're doing a fabulous job on her..... Regards Alan
Nice work John, looks stunning. Mark Regards Markwarren (Mark) Admin
Martyn Ingram wrote: Very nicely done she is starting to look the biz Martyn Hi Martyn Thanks for looking in and the nice words of encouragement... Regards JohnP
