10 Pages «<45678>»
Ant62 victory build Options
Ant62
#101 Posted : 14 May 2019 18:08:27
I decided to take the girl downstairs into the kitchen to do a bit on the next lot of canon ports that was a non starter.
Scapel still up stairs so went to get it.
The 12mm x 12mm template again upstairs so off i trudged....
Started the 3 canon ports half wya through the first one ping blade snapped and guess where the blades where!
Yes upstairs....
So i ended up taking the girl back up.....
Ant62 attached the following image(s):
Building.
HMS Victory.....
Corel Albatross 1840......Completed
Hindenberg Zepplin museum piece..Completed
Artesian Latina Sopwith Camel.....Completed
Bismark.........
#102 Posted : 15 May 2019 06:09:01
Hi Ant62, looking good you must be very pleased with your work, those ports are a bit trick at best,with my build i drilled around the shape and then used a small file to finish off.
trev.
#103 Posted : 15 May 2019 08:18:37
Looking good.....Cool Cool
Ant62
#104 Posted : 15 May 2019 13:31:47
trev.
Surprisingly quite quick using the scapel and you get to know its uses....
Building.
HMS Victory.....
Bismark.........
Ant62
#105 Posted : 16 May 2019 15:06:47
I have almost completed the 3rd level of canon ports and according to the official videos i should have painted cut the 20mm and 15mm blocks..
Now these length of wood are not in the packets stage as or as in the videos or the pdf....
So do i cut them and place them to cover the upper deck canon port as in the picture..
Building.
HMS Victory.....
Bismark.........
z8000783
#106 Posted : 16 May 2019 15:11:35
Groups: Unapproved
Yes, they serve two purposes.
Firstly they need to be drilled to take the dummy cannon so they need to go above half way. Secondly, the whole area needs to be painted black in order not to let light though.
These should have been in place before laying the middle deck.
Ant62
#107 Posted : 16 May 2019 15:29:31
Well following the video and the PDF say when to place these pieces of wood but infact they arrived in a later box so i couldnt paint cut place them...
But never mind it will do it later after the canon ports are cut..
Building.
HMS Victory.....
Bismark.........
z8000783
#108 Posted : 16 May 2019 15:38:16
Groups: Unapproved
I went off track a few times during the build for a reason but you need to be absolutely clear what you are doing and why. Generally though, it is best to follow the build process to the letter, even if it might mean waiting, to ensure that you can do what you have to do at a later time.
Ant62
#109 Posted : 16 May 2019 18:12:01
Quite easy done to go off course...
So justvto clarify the cut blocks are to be placed behind the upper deck canon port make it look like the lower decks....
Building.
HMS Victory.....
Bismark.........
z8000783
#110 Posted : 16 May 2019 19:10:54
Groups: Unapproved
No, I took a different route on occasion but I did a lot of research to make sure I didn't create any problems for the future. As I say though, at the detailed level, it's important to follow the instructions fully.
Ant62
#111 Posted : 16 May 2019 19:45:57
Right im lost now.....
The black cut 15mm or 20mm block goes A next to the canon port or B behind the canon port...
Building.
HMS Victory.....
Bismark.........
Ant62
#112 Posted : 16 May 2019 20:17:18
I have now sussed it after watching the video again again again very carefully....
Building.
HMS Victory.....
Bismark.........
z8000783
#113 Posted : 17 May 2019 06:31:12
Groups: Unapproved
It goes behind the port in order to take the dummy cannon. You will need to drill into it right in the centre of the gun port.
#114 Posted : 17 May 2019 09:24:15
Making good progress Ant, well done....Cool Cool
Ant62
#115 Posted : 17 May 2019 13:40:29
Ive taken a short break away from the build for a while etc
A fresh look at the build later.....
Blushing Blushing Blushing just realised i have missed several canon ports have to do them and then leave the build for a bit....LOL
Building.
HMS Victory.....
Bismark.........
Ant62
#116 Posted : 19 May 2019 19:21:59
Well finished the canon ports on both sides....
Have a break from it now need to be freshened up to do the hull....
Building.
HMS Victory.....
Bismark.........
#117 Posted : 20 May 2019 08:17:01
Very nice progress, looking good.Love
#118 Posted : 20 May 2019 16:32:08
Very neat work.
That is a whole load of cut outs you have to do but well done for getting to the end of them.
Tony
Ant62
#119 Posted : 21 May 2019 09:15:59
birdaj2 wrote:
Very neat work.
Tony
Thanks for that...BigGrin
Building.
HMS Victory.....
Bismark.........
Ant62
#120 Posted : 21 May 2019 09:19:06
Well here is the lady hull side up....
Building.
HMS Victory.....
Bismark.........
10 Pages «<45678>»
