25 Pages «<23456>»
Gandale's Vasa Build Options
#61 Posted : 05 June 2019 11:24:59
Awesome work Alan, doing a mighty fine job on your Vasa.
Chris
#62 Posted : 05 June 2019 16:12:59
Thanks to everyone for looking in and your continued support, always appreciated.....Cool Cool
CaptnBirdseye
#63 Posted : 06 June 2019 12:14:02
Rank: Superelite
Superb work as always Alan ThumpUp
#64 Posted : 07 June 2019 08:22:48
Thanks for your comments and support Gray, appreciated....Cool Cool
Kev the Modeller
#65 Posted : 08 June 2019 11:00:06
Very nice work Alan. Making and painting all of those gun doors must have been a mind-numbingly repetitive exercise but a great end result with all of them looking identical and well worth the time taken?
Well done, looking really good. CoolThumpUp
Per Ardua Ad Astra
#66 Posted : 09 June 2019 17:04:07
Hi looking good, decorations are great very well painted ,cheers mick, BigGrin
#67 Posted : 10 June 2019 23:23:51
Mick, Kev, thanks for looking in and for your comments, appreciated....Cool Cool
@Kev, the repetitive and tedious parts of the build are not too bad for me. I simply look at the build stage and break it down, such as doing perhaps 10 gun port lids then move on to doing some of the painting on castings before doing some more gun port lids and so on. The tedious parts is all part of model ship building and is something I have gotten used to and still enjoy.....BigGrin BigGrin BigGrin
#68 Posted : 18 June 2019 21:10:55
Stage 99 Contents: Decorations, Hinges and Wooden Dowels.
Retrieve the PE fret containing the hinges. You can choose whether to blacken the hinges using a blackening solution or to paint them metallic black (RAL 5011), I chose to paint them. Once dried, gently file the raised parts of the hinges to remove the paint, exposing the metal underneath.
Recover one of the gun port doors from stage 98 and glue two hinges onto the outside of the door, positioning them 2mm in from the sides. Repeat the process on all the gun port doors.
From the 2mm dowels supplied with this stage, cut 54 pieces each of 20mm in length. Store the gun port doors and dowel sections in a stage labelled bag.
Remove any burrs or flash from the decorations supplied with this stage. Apply a coat of metal primer and leave to dry.
Follow the painting guide provided within the instructions to paint the decorations. When dry, carefully store the decorations in a bag labelled with this stage number.
This stage is now complete.
#69 Posted : 18 June 2019 21:20:18
That looks very good.
For your gun port hinge pins have you used nails with the heads cut off or have you used pieces of brass rod.
They look very neat.
Think looking at the pictures again i answered my own "silly" question. I can see now from on of the pictures that had not loaded that the pins are molded into the etch hinge strap.
It had looked like you had put pins in the hinges to hold them to the port lids.
Either way looks good.
Tony
nightwisher
#70 Posted : 18 June 2019 23:55:51
The gun port lids do look very smart with those fancy hinges and decorations are immaculate Love
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#71 Posted : 19 June 2019 06:44:43
Top work again Alan thank you for posting.
Trev
DaDokta
#72 Posted : 19 June 2019 09:11:17
Simply awesome!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
CaptnBirdseye
#73 Posted : 19 June 2019 09:45:02
Rank: Superelite
BigGrin Some fine detail there Alan Love
#74 Posted : 19 June 2019 09:56:12
Blimey - all those doors!
Amazing work there.
#75 Posted : 19 June 2019 15:31:08
Amazing work Alan, excellent.Love
Kev the Modeller
#76 Posted : 19 June 2019 20:18:31
Excellent work as always Alan, you really are a master at building these ship models. Your detail painting of those decorations is first rate.
Very well done. ThumpUp
Per Ardua Ad Astra
#77 Posted : 19 June 2019 23:19:17
Thanks guys for looking in and your very positive comments.... Appreciate the support as always.....Cool Cool
#78 Posted : 20 June 2019 17:50:06
Love it Alan.
Trev
#79 Posted : 20 June 2019 19:07:25
BigGrin More stunning work Alan Love
Martyn
#80 Posted : 21 June 2019 15:51:08
Wow great painting on these vasa kitsDrool lovely work AlanBigGrin regards PhilCool
Guest (18)
25 Pages «<23456>»
This page was generated in 3.111 seconds.
