4 Pages 123>»
Another lightweight E Type build Options
#1 Posted : 06 June 2019 09:52:39
As many of you who have been here for a while possibly know, I'm a bit of a Jaguar fanatic, particularly the E Type.
I've built 2 lightweights so far using parts from the large 1/8 Revell kit and will soon be starting on a long-nose streamline car.
Master bodywork moulds in prep at present.
However, I've got a spare roadster tail end in my 'bits' box, as well as a lightweight bonnet with 4 lights that I never got round to using.
A bit of Googling found a suitable car so I'm going to have a go at this one next as a bit of a 'filler' project between other things.
#2 Posted : 06 June 2019 19:06:01
Just a little update.
This conversion of the Revell kit needs the front body parts to be taped in place, to get the correct location of the roadster tail.
It also needs the interior floor to be heavily altered as the race cars don't have the same tunnel configuration.
A bit of chopping and gluing done.
The kit bonnet is only taped to get placement for the front scuttle.
The bonnet part won't be used.
#3 Posted : 06 June 2019 19:46:34
Good luck with this one Roy.
Looks like its going to be a very eye catching model.
Silly question maybe but are you planning on finishing it in Red?
Tony
Kev the Modeller
#4 Posted : 06 June 2019 19:52:24
Looks like another cool E-Type coming from you Roy. Good luck with the build and I love the look of the full size car, gorgeous in red! Cool ThumpUp
Per Ardua Ad Astra
andali15
#5 Posted : 06 June 2019 19:54:04
Wow Roy, this will be some build. Good luck but with your knowledge of modelling you won’t need it. Will follow you through the build. Andy
#6 Posted : 06 June 2019 20:10:55
Thanks chaps.
I don't 'intend' going nuts on the detailing (we shall see) as it's just an 'in-between' build as I've got other projects on the back burner.
Yes, it will be red and with the same markings etc as the pictures.
I have a streamline long nose E Type in the works, as well as a full-detail XK120...
Kev the Modeller
#7 Posted : 06 June 2019 20:21:38
The XK120 sounds cool Roy, will certainly be watching and commenting on that one, such a beautiful car and one of the best looking Jaguars in my opinion! Drool ThumpUp
Per Ardua Ad Astra
#8 Posted : 06 June 2019 20:26:25
Thanks Kev.
The XK120 is one I've had in mind for a long time.
As soon as I start on it I'll be posting.
In the meantime, here's the actual front end I'll be using on the E Type.
RM1
#9 Posted : 07 June 2019 11:21:40
Another great looking project Roy.
I like the sound of the XK120... That would quite something.
Malc.
#10 Posted : 08 June 2019 13:41:13
Thanks chaps.
A bit more on the floor section.
Race E Types have a very spartan interior and as such the transmission tunnel is usually just covered with an insulating fibreboard.
I replicated it with surgical fabric tape painted matt black.
Also, I added the strengthening ribs on the floor and added the missing cross-braces.
Firewall glued in place ready for modifying...
#11 Posted : 11 June 2019 19:49:46
Another update for those following.
I've now added the front firewall as well as making the (missing) infill panels - still more to add around here.
Also, the tail halves are now bonded together, along with a thin strip of plastic which will later be shaped into the weld seam.
I'm not making an opening boot on this one as it really is just a 'test piece' for my roadster tail.
The front scuttle is now fixed in place as this part is critical for the fit of the roadster part.
The door skins are just taped in place to get the proper location for the tail.
Once it was marked on the sills, the door skins were removed and the rear part Araldited in place.
I'll leave it to harden until tomorrow.
After that, more strengthening will be added underneath and along the back tub wall.
#12 Posted : 11 June 2019 20:36:36
Looks to be coming along a treat Roy.
Tony
#13 Posted : 11 June 2019 21:55:19
Thanks Tony.
Fingers crossed...
#14 Posted : 13 June 2019 08:57:27
Not much progress here yet but I've removed the tail section and re-fitted it with much heftier fixing tabs and added a support panel under the car, behind the cockpit rear wall.
Some filler added at the joins etc so a day or so to harden off before sanding it smooth.
#15 Posted : 13 June 2019 09:29:08
Very nice progress Roy, great to see your idea's come to fruition.....Cool Cool
#16 Posted : 13 June 2019 16:59:33
Thanks Alan.
As I mentioned at the beginning, this one is just really a 'test bed' for my resin roadster tail.
I'm not going overboard, and I'm deliberately using a lot of the Revell kit instead of just using the floor pan, front firewall, bonnet and screen scuttle which is what I usually do. I normally even cast my own resin engine parts.
I'm still going to add a lot of engine detail and scratch my own interior and wheels/tyres.
To begin, I've started adding the missing engine frame parts.
#17 Posted : 13 June 2019 20:40:45
You certainly are a fast worker Roy snd its taking shape so well.
If thatcwas me i would be sat there thinking "what do i do next".
Tony
#18 Posted : 13 June 2019 20:49:17
Tony - I'm ALWAYS thinking 'what do I do next?'...
Luckily, I'm a retired geezer who has about 8 hours a day to fiddle with models (and other stuff) so yes, it does seem to rattle on quite quickly.
#19 Posted : 21 June 2019 16:48:45
This one hasn't been forgotten.
I've added more to the engine frame - still more to add.
The joins between the scuttle and base have had filler and sanding, the same around the tail where it meets the base.
Lots of sanding, and now a spot of primer so I can sand and see where it needs more filling and smoothing...
#20 Posted : 21 June 2019 22:23:36
Lovely progress Roy, excellent work as usual....Drool Drool
4 Pages 123>»
This page was generated in 0.317 seconds.
