Rank: Administration  Groups: Administrator, Administrators, Forum Support Team, Global Forum Support, Global Forum Support Team, Moderator, Official Builds Joined: 24/08/2009 Posts: 1,943 Points: 5,841 Location: UK
New members: Will remain 'Unapproved' until at least 2 posts have been made, thereafter will show as 'Registered' and 'Rank' displayed. Delboy271155 is in charge of new member registration, so please PM him if you encounter problems. If no post is made within 3 months of registration, your membership may be returned to 'Guest' status and you will need to re-register.[/b]
Existing members: If no post has been made within 12 months of the date of your last post, the system may return your membership to being 'Guest' status and you will need to re-register.
Cookies & Privacy:
Cookies: The forum system uses Cookies to store information on your computer, which only serve to improve your viewing pleasure. Your e-mail address is used only for confirming your registration details and password, (and for sending a new password should you forget your current one), and to contact you directly should the need arise.
Privacy: ModelSpace does not distribute marketing email via the forum or supply your contact details to any outside agency, and is held on a secure database. Should you no longer use the forum, you can request (by PM to any of the Admin team), to have your Username and details deleted from the forum system, (once deleted it cannot be reinstated and you will need to re-register).
documents
