3 Pages <123>
Fugimi 1/24 Ford GT 1967 build. Options
#21 Posted : 04 July 2019 22:23:38
BigGrin Yup special doors were made for himLOL LOL
#22 Posted : 04 July 2019 22:24:45
BigGrin The interior is done now onto the body shellDrool Drool Drool Huh
#23 Posted : 04 July 2019 23:09:43
Lovely work Andy, all looking good....Cool Cool
#24 Posted : 05 July 2019 18:26:48
BigGrin Thanks for looking in and your comments AlanCool
#25 Posted : 05 July 2019 19:26:01
BigGrin The body has been cleaned up the rear wheel arches added and filled where needed. Now the 1st coat of black primer has gone on. This will show up anything I missed and also anything that needs more work. Cool
#26 Posted : 05 July 2019 20:44:42
Very nice work Andy, doesn’t look like you’ve missed anything to me. Love
#27 Posted : 05 July 2019 20:54:19
I assume you are using Zero paints? What kind of primer do you use. I finally got some ordered (well in theory since it was backordered but they told me it would be coming back soon), but I am not sure which primer to use.
pS Looks fantastic .Cant wait to see some color on the body
Kev the Modeller
#28 Posted : 05 July 2019 21:03:05
Making great and speedy progress with this as with all of your builds and looking good so far Andy, well done. ThumpUp
Seeing your finished interior brought back memories of my '66 Le Mans GT40 build from a few years back. I noticed that you haven't painted the rings that are moulded in the seats in a silver/chrome finish? I did that on mine as I'm sure they're metallic rings on the real seats, but I don't blame you if you decided not to, they are very fiddly to paint! Blink
Nice work.
Per Ardua Ad Astra
#29 Posted : 05 July 2019 21:56:52
BigGrin Hi Kev
The instructions are all in Japanese and the only colour flagged for the seats is semi gloss black on them, but thanks for the heads up. Thanks for looking in and your comments.
Its the same with the wheel knock offs there supplied as chromed parts but they were colored red and blue as each side had a different thread and were colored to prevent cross threading.
#30 Posted : 05 July 2019 22:12:38
Hi Carl
The black undercoat used here is Mig-Ammo's one shot acrylic as an indicator to show any blemishes, most of this will disappear tomorrow with the final rub down. the inside will be sprayed with Alclad so needs to be black.
Any good spirit based undercoat will be fine for Zero, they do do there own as all paint producers do, just make sure its prepped correctly and the Zero will go on fine. The enemy of Zero paints is dust/fluff so do a good clean down and wear a good mask against the fumes.
#31 Posted : 05 July 2019 22:15:00
There will be some scratches present from the seam removal nd it will show any other blemishes.
#32 Posted : 06 July 2019 14:11:30
BigGrin The bodyshell was inspected and any clean up done then a coat of white undercoat went on and was left to dry. Once dry two coats of Zero metallic blue went on. Once dry the decals will go on. Cool
Kev the Modeller
#33 Posted : 06 July 2019 14:51:58
Nicely sprayed and a beautiful colour Andy. Is that the same blue that you used on your MFH Cobra build? It really suits the GT40!! Drool ThumpUp
Per Ardua Ad Astra
#34 Posted : 06 July 2019 18:49:14
Thanks for looking in and your comments Kev.
The blue is Zero paints equivalent to Tamiya,s metallic blue the Cobra was done with a different blue but there not far off from each other colour wise.
#35 Posted : 06 July 2019 18:51:11
BigGrin The decals are on now to leave overnight and clearcote tomorrow. Cool
CaptnBirdseye
#36 Posted : 06 July 2019 18:56:50
Rank: Superelite
Drool Love Love Love WOWLove Drool Love Drool
#37 Posted : 06 July 2019 22:42:16
Beautiful Andy, I do love the paint finishes you achieve on your car builds and this one is no exception.... Very skilfully done.....Drool Drool Drool Drool
#38 Posted : 07 July 2019 01:19:19
stunning.Do you need to rub down the zero paint or is it smooth enough once applied
#39 Posted : 07 July 2019 10:55:48
#40 Posted : 07 July 2019 11:08:45
Firstly make sure you have a good face mask when spraying Zero paints the fumes are not good for you lungs.
I usually spray it with light coats building up the colour until there's an even coat. Airbrush splatter can be rubbed back if your unlucky enough to get some as can runs from a too wet application. But for the most part it sprays fine and you can put decals straight onto the paint once its dry.
All Zero paints will need a clearcote I use there Diamond 2 pack on cars. Just remember to put a mist coat over the decals then leave for 10 minutes. After 10 minutes put on your 1st wet coat then leave for another 10 minutes and then another final wet coat and leave to dry.
3 Pages <123>
