26 Pages «<89101112>»
MWG build diary of the Bark HMS Endeavour Options
#181 Posted : 08 August 2011 21:10:20
Cheers mateBlushing
#182 Posted : 08 August 2011 23:01:00
Hi again just useing up the remainder of the planks from issue 28 I thought you would like to see the photos:-
#183 Posted : 08 August 2011 23:05:49
Now we have a view from the other side, the planks will have to be sanded level to the Bulwark top as you can see by this last photo, thank you for watchingBigGrin
#184 Posted : 09 August 2011 00:20:52
Looking good M8.. Keep it up.. Your a busy man.. Looking through all your builds.. lol..BigGrin BigGrin Flapper
#185 Posted : 09 August 2011 00:26:44
Thanks Chris,
Always appreciate your words of encouragementBigGrin Cool I love what I am doingDrool
#186 Posted : 10 August 2011 19:35:50
As I posted before I was not happy with the standard of cannon supplied with this build, well I am over the moon, because after some serious research by myself and a friend Alan I have found the cannon that ticks all the boxes, and here it is ( thanks for you input Alan)
#187 Posted: : 10 August 2011 19:43:07
Needless to say I purchased enough to complete the build.
Thank you MrT for your input, in responding to my queries BigGrin
PDyner
#188 Posted : 11 August 2011 10:32:06
Hello
I'm building her as well, and as you I think the supplied cannon is awful. Could you give us any clues where you bought yours cannons,please ??. If it will be breaching some of the forums rules you can always PM me, please
Happy building
Prem
Prem Dyner
#189 Posted : 11 August 2011 10:42:58
That be one of the Caldercraft cannon kits
http://www.jotika-ltd.co...1024768/Fitting_Arms.htm
#190 Posted : 11 August 2011 12:07:35
Mr T as usual is correct this is the item :-
All though the scale is not 1/48 (the cannon are 1/64) they are compatible with this buildCool
#191 Posted : 11 August 2011 18:27:40
Hi everyone I have done some more planking,(I purchased 10 mtr of 2m x5m of first class planking)the planking supplied with the build is different thiknesses, I know its not critical being the first planking stage, but the planks supplied are unpredictable here are some photos :-
PS the tops of the waist and stern Bulwarks where the planks come over the top will be filed down.
#192 Posted : 11 August 2011 18:35:19
At the Bow the lower plank going around the bow bulwark, is now fixed the planks with the pins in are wet having been soaked in water, and dry fitted, so when dry they will hold their curve (note the bad quality of the bottem plank)Blink
#193 Posted : 11 August 2011 18:42:10
Next I have fitted the Gardboard planking Here are the Photos and thats all for this session.BigGrin
#194 Posted : 11 August 2011 20:14:05
This is this weeks issue no 29, it contains another 20 planks plus an anchor.
The anchor calls for 2mm x 5mm stained walnut, I have decided to use dark wood of a thicker size giving no joins and a better finish.
In stead of using nails I will drill the wood and insert pieces of brass rod because if I use nails when I trim them the ends will show the steel core of the nail.BigGrin
#195 Posted : 11 August 2011 23:06:30
Did some more work on the planking tonight, will show results tommorrowCool
#196 Posted : 13 August 2011 10:33:49
Ok here is the latest work on the planking:-
First some planking on the base of the Hull (still to fine sanded)
#197 Posted : 13 August 2011 10:37:48
I have now trimed all the Bulwarks, and finished planking the top half of the Hull, you can now see the shape:-
#198 Posted : 13 August 2011 10:40:23
And the Waist:-
alantait
#199 Posted : 13 August 2011 10:42:38
really looking good mwg, hope the second planking is better that the first though, some of mine are very rough, might end up ordering new stuff online
current builds
#200 Posted : 13 August 2011 10:43:24
And finally the Bow (please note how the planks go around the Bulwark)
All yet to be sanded. Thats all for now.
This page was generated in 0.318 seconds.
