 Rank: Pro Groups: Registered
Joined: 08/02/2015 Posts: 426 Points: 1,259 Location: Louisiana
hello there I have a question how come the arm seal does not require screws to keep it in place from falling out like mine does or do they get fasten later in the construction thank you Ronald
Rank: Administration  Groups: Administrator, Administrators, Forum Support Team, Global Forum Support, Global Forum Support Team, Moderator, Official Builds Joined: 24/08/2009 Posts: 1,943 Points: 5,841 Location: UK
The “arm seal?” Do you mean the twist-lock shoulder mount cap?
It gets tighter when body panels go on.
no the silver arm seal in issue 68 it just says snap in to place but it doesn't stay in place Ronald
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,421 Points: 22,573 Location: Northamptonshire, England
The silver arm plate will hold itself in place when you come to attach the arm assemble to the body. Regards Mark Regards Markwarren (Mark) Admin
Joined: 28/12/2018 Posts: 67 Points: 213 Location: United States
In some cases, the part snaps in and stays, but in most cases, it slips out. I'm not saying to do this, but I added 2 drops of CA just to tack it in. Fred
ok thanks Fred sounds like a good idea because mine keeps popping out Ronald
Just don't completely glue it. Just a dab to hold it. ronald305 wrote: ok thanks Fred sounds like a good idea because mine keeps popping out Ronald
Joined: 04/08/2017 Posts: 73 Points: 243 Location: Missouri, USA
I assume you mean the half round pieces that attach to the body at the shoulder. If so, a drop or two of superglue will hold for now, but when assembled, the legs will prevent those pieces from going anywhere.
