80 Pages «<6364656667>»
Sticky Wickett
#1281 Posted : 22 November 2019 09:00:39
Front view.
Sticky Wickett
#1282 Posted : 22 November 2019 09:01:45
That concludes this weeks update.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
#1283 Posted : 23 November 2019 00:16:50
Beautifully done Phil and great to see some of your techniques..... love it....Love Love
#1284 Posted : 23 November 2019 10:02:04
Super work Phil, loved the pictures at the beginning. Going to be a stunner when finished.Love Drool Drool Drool
Sticky Wickett
#1285 Posted : 28 November 2019 19:56:11
Thank you Alan. Glad you like my home made lathe!LOL
Phil W.
Sticky Wickett
#1286 Posted : 28 November 2019 19:57:18
Thank you Mark. Don't worry, you're invited to the launch party!LOL
Phil W.
Sticky Wickett
#1287 Posted : 28 November 2019 19:59:56
This week i have finished the rear torpedo tube door by fitting the grab handle and also a drain.
See attached photo.
Sticky Wickett
#1288 Posted: : 28 November 2019 20:00:51
The drain plug is at the bottom of the tube rear door.
Sticky Wickett
#1289 Posted : 28 November 2019 20:05:17
The next job was to make the piston. This device is pushed up behind the loaded torpedo, compressed air then pushes against the piston which in turn forces the torpedo out of the tube. When not in use, it is stored to the side of the torpedo tube.
I started by making a cylinder using 0.25mm thick plastic sheet. Blanked off one end and notched out four cut-outs around the circumference on it's open end.
Sticky Wickett
#1290 Posted: : 28 November 2019 20:08:07
I made the piston adjusters using 0.8mm diameter brass tube and 0.6mm brass rod, joined together with Albion Alloys brass 'Connecto'; similar to how i made the guard rails for the conning tower.
Sticky Wickett
#1291 Posted : 28 November 2019 20:10:12
Piston completed.
Sticky Wickett
#1292 Posted : 28 November 2019 20:11:06
I then fitted a small stand underneath it.
Sticky Wickett
#1293 Posted : 28 November 2019 20:13:21
All three items I've mentioned photographed together. They all require painting, but first i have to fit some of the pipework, which i'll start next week.
Sticky Wickett
#1294 Posted : 28 November 2019 20:14:28
Another update will follow next week.
Thanks for looking in and your comments, have a great weekend and happy modelling!BigGrin
Phil W.
#1295 Posted : 29 November 2019 00:00:09
Looks great Phil, look forward to the next update.....Cool Cool
DaDokta
#1296 Posted : 29 November 2019 08:33:44
Incredibly detailed build! Wonderful!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Sticky Wickett
#1297 Posted : 29 November 2019 11:28:13
Thank you very much Alan!Cool Now it's time to start figuring out how to fit all the pipes!Blink
Phil W.
Sticky Wickett
#1298 Posted : 29 November 2019 11:28:46
Thank you very much Walter!Cool
Phil W.
#1299 Posted : 29 November 2019 15:27:49
Nice work Phil as usual.Love Drool Drool
#1300 Posted : 30 November 2019 00:13:01
Phil W.
Fitting them carefully would be a good start......LOL LOL LOL
This page was generated in 0.356 seconds.
