Joined: 28/12/2018 Posts: 67 Points: 213 Location: United States
Someone had already asked this and never got an answer. I got my charger mixed up  with some others and not sure which one it is. Does anyone in the US preferably since that is where I'm at, know how to be able to identify it or know the specs. I think it is a 15v. Thanks in advance. Fred
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,033 Points: 21,406 Location: Northamptonshire, England
Hi Fred Although I’m in the UK, the one I have is an output of 15v - 2000mA. Hope that helps Mark Regards Markwarren (Mark) Admin
Thanks Mark. I knew it was probably one of my 15v, and the plug should be a negative center correct? As it happens, I have an old color computer that uses a 15v, and one of these is a negative center and one has a positive center. But after I get this sorted, I am getting a Sharpie and some tags Thanks again Mark Markwarren wrote:Hi Fred Although I’m in the UK, the one I have is an output of 15v - 2000mA. Hope that helps
