Joined: 07/08/2015 Posts: 10 Points: 30 Location: Australia
Hi could someone give me the measurements of the 10 mm eyebolts internal hole and outer I didn't get them with my issue I am on issue 113 part 24 it said to use 10 mm eyebolts but I didn't receive any can you use 7 mm eyebolts will it work thanks
Rank: Administration  Groups: Administrator, Administrators, Forum Support Team, Global Forum Support, Global Forum Support Team, Moderator, Official Builds Joined: 24/08/2009 Posts: 1,943 Points: 5,841 Location: UK
Give CS a call. They will replace any missing or damaged parts.
Thanks for reply Mark who is cs thanks
Hi Nib, using 7mm eyebolts shouldn't cause you any problems, just ensure they are securely glued into position.
