4 Pages <1234>
X-Wing Official Build Custom/Enhancements Options
#41 Posted : 03 October 2020 15:35:46
OMG - WOW
That tiny screen is absolutely awesome. What a find.
ThumpUp ThumpUp ThumpUp ThumpUp ThumpUp
Wabie
#42 Posted : 03 October 2020 16:11:04
Groups: Registered, Forum Support Team Germany, Official Builds, Tech Support, Moderator, registriert, Administrators
Hello Mark,
a very nice job. Love
I'm curious how it looks finished. Smile
A good solution. ThumpUp
greetings stefan
Alle Berichte sowie alle Fotos unterliegen dem Urheberrecht. Verwendung außerhalb dieses Forums bedürfen schriftlicher Genehmigung/Zustimmung meinerseits. © Stefan
Forum Support Team
https://m.youtube.com/watch?v=qIC4f1LE86w
MfG Stefan
#43 Posted : 04 October 2020 09:37:38
delboy271155 wrote:
OMG - WOW
Thanks Derek.
Didn’t know they made such thing’s until looking around on the internet. They are not cheap, but probably no more than other after market parts.Cool
It took a lot of fiddling to get it to fit, but well worth it.
#44 Posted : 04 October 2020 09:40:24
Wabie wrote:
Hello Mark,
greetings stefan
Thanks Stefan
Well there’s no turning back nowCrying a lot of work to do but I hope it will look the part when finished.
corelki2005
#45 Posted : 04 October 2020 13:21:48
Is it possible for a link for the screen please
#46 Posted : 04 October 2020 14:27:46
No problem, here you go
X-Wing screen link
#47 Posted : 12 October 2020 20:04:28
Just a quick update, parts sanded down, primed and the painted with base colour. Solved where all the lighting will be, which will be shown soon. Next, gloss varnish and decals placed.
More soon
clay
#48 Posted : 13 October 2020 15:01:37
Oh how I loathe you Mark!!!
Beautiful!!! Now I gotta convince my wife to let me get that screen...if they are still available!!!
Looking forward to your next update!!!
#49 Posted : 23 October 2020 16:23:42
Thank you for looking in Clay.Cool
Just a little update. I have now added all the decals onto the cockpit panels. This was done over a three-day period and was not easy. All the lights had to match the hole in the etched brass and if it moved once it moved a dozen times, so only placed on a couple at a time to dry before proceeding with anymore. Once these were placed, I varnished it with satin varnish, left to dry before placing all the greeblies on. The whole thing was then dry brushed with a delicate silver, you can hardly see it, but gave the whole piece that metallic feel and highlighted certain areas.
The last picture shows a couple of bulbs placed on the underside to show and give some idea to the lighting effect.
Next, I will be colouring some of the lights with red, blue, and green on the inside. The lighting will be micro strip lighting with a very bright finish, some flashing smd’s as well as a few fiber optics before attaching the visual screen.
Still a lot of work to do.Cool
More soon.
clay
#50 Posted : 23 October 2020 16:32:04
Mark,
How did you wire the screen? Into the existing wiring???
This freakin looks amazing!!!
Clay
#51 Posted : 23 October 2020 17:32:23
Hi Clay
I haven’t wired the screen in just yet, the picture shown is just the light from LED’s coming through. I will show on the next update how it will be done, but the extra lighting inside and screen will be on a separate circuit. Adding these to the supplied circuit board might effect it or at worse blow it.
I’m looking forward to it all in place myself.
BTW, did you manage to persuade your lovely wife to get one?
Thanks
#52 Posted : 23 October 2020 17:39:11
Well I`m sure most of us have heard of ELO. (Electric Light Orchestra)
On the forum we now have our very own ELM. No not a tree, its Electric Light Mark.LOL LOL LOL
WTG that man, more amazing stuff. Cool Cool Cool
#53 Posted : 24 October 2020 08:37:59
Thanks Derek.LOL LOL LOL
I’ve also been called a lot of other things but let’s not go there.LOL LOL LOL
Anyway, that was just a teaser, Laugh it will be Blackpool illuminations when finishedLOL LOL LOL
Andreas
#54 Posted : 24 October 2020 17:37:13
Groups: registriert
Hi Mark,
i'm almost back. Everything survived well. Go to rehabilitation now. My family brought me my laptop. I have to be up to date.BigGrin BigGrin
To have a look at your builts is always great! That's just awesome!BigGrin
best Andreas
Forum Support Team
#55 Posted : 25 October 2020 09:00:58
Thank you Andreas.BigGrin
Really please you are making great progress, just take it easy. At least you won’t get bored now you have a laptop.
clay
#56 Posted : 26 October 2020 11:33:59
No...I haven't ordered mine yet!
Most excellent job Mark Warren!!!
#57 Posted : 31 October 2020 22:07:22
Now the panels have had time to dry, I have used some micro crystal clear on the underside before painting individual windows with some colour. I decided not to go over the top with the colouring, less is more as they say.
I then placed the OLED screen inside and fixed it in position using some double-sided tape. This gives me the option of taking it out for servicing should I need to in the future.
When placing the screen in place, I noticed there was a 1mm over run on the underside when fixing the cockpit panel onto the base. I had to cut a ridge out and fill the underside with a piece of styrene giving me that 1mm recess for the screen. After that, I wired 4 strips of LED lighting on the top of the base for the lighting under the cockpit panels. These will be run on a 9v supply independently from the supplied lighting. The screen is also attached to the 9v supply with a buck convertor dropping the voltage to 5v.
I have also painted some detail on the back of the cockpit panels.
The supplied lighting for the cockpit is still used in the two side panels and the screen bulb will be placed in the rear of the cockpit supplying lighting to this area. This will be done next.
I have also done a video to show the screen working.
https://youtu.be/haxLW8aZQ4s
More soon
#58 Posted : 31 October 2020 23:42:29
That looks brilliant.
All that lighting adds so much to the model.
#59 Posted : 01 November 2020 16:12:56
WTG Cool Cool Cool Cool Cool
Who needs Blackpool Illuminations.
Just watch Mark`s X-Wing. Careful you don`t drain the national grid, it gets dark earlier these days.LOL Flapper LOL
Keep up the good work on the enhancements. I`m loving it.
Andreas
#60 Posted : 01 November 2020 17:00:17
Groups: registriert
I can only agree,BigGrin
I subscribed to Mark on YouTube a long time ago.
if someone wants to expand his skills, then this is the right channel to do that.
The cockpit is just awesome! excellent Job!BigGrin ThumpUp
Forum Support Team
Guest (15)
4 Pages <1234>
This page was generated in 0.314 seconds.
