56 Pages «<45678>»
MWG build diary of the mighty Hood Options
S2ksean
#101 Posted : 14 September 2011 12:07:26
My newsagent was supposed to get this but apparently it wasn't delivered. Now I gotta get it tomorrow it's no big prob but tomorrow was my day off and didn't wanna go out lol never mind
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#102 Posted : 14 September 2011 12:19:53
Hi Sean hope you get it tomorrowCool
#103 Posted : 14 September 2011 19:40:13
ISSUE 3
Here are the parts cut out, sanded and ready to fitCool
Silent_Running
#104 Posted : 14 September 2011 20:12:09
It's looking real good Mike! ThumpUp I'm watching with interest. By the way I have joined the build of HMS Hood myself. I'm waiting till I have enough parts for a decent start, so I'm stowing them away till then.
By the way, I just wanted to thank you for your input and thoughts when I was at the will I, won't I, stage.
You know what its like just before you sign up to a new build, especially one as big as this, you get an attack of the nerves. Your analysis and thoughts about the build were dead on. So thanks for that mate. ThumpUpBigGrin
Also a big thanks to Colin, whose infomation and enthusiam for the build has been quite infectious. Thanks to you both! BigGrin ThumpUp
Zeptrader
#105 Posted : 14 September 2011 20:18:56
Glenn, that mighty fine of you, thanks, but me ...infectious??? now thats something:) serious, cheers and no problems.
MWG, speeding ahead and looking fine, I've got my issue 3 tonight but wont make a start on that till Sunday at the latest.
#106 Posted : 14 September 2011 20:26:36
Hi Glenn thank you for your kind comments, and your very welcomeBlushing
Hi Colin, yes I have a lot on the go but I am loving it, both my grand daughters are involved helping meBlink Cool looking forward to your build on SundayBigGrin
#107 Posted : 14 September 2011 20:28:32
ISSUE 3
Here are all the parts received this week fitted in place :-
Zeptrader
#108 Posted : 14 September 2011 20:32:00
Found an interesting little site -
http://www.hood.partwork...ls.co.uk/modelframe.htm
shows the decking at issue 17? this guy has done the Bismark and is part of the partworksmodel forum
http://www.partworkmodels.co.uk/phpBB3/
#109 Posted : 14 September 2011 20:33:20
More photos :-
#110 Posted : 14 September 2011 20:36:12
Thanks for that Colin a great postThumpUp
#111 Posted : 14 September 2011 22:53:01
Looking good mike BigGrin
#112 Posted : 14 September 2011 23:00:28
Thanks Ian hows things?
#113 Posted : 14 September 2011 23:07:52
not to bad mike you. getting on quite well wit bismarck about two issues untill she`s finished. still loads to do on her Ian. BigGrin
#114 Posted : 14 September 2011 23:54:57
I am sure you will get there, me I am just enjoying myselfCool
#115 Posted : 15 September 2011 00:45:20
great stuff mike
#116 Posted : 15 September 2011 01:16:16
Cheers IanCool
willie
#117 Posted : 15 September 2011 10:42:18
i ant steeling your log just showing different ways of clamping
#118 Posted : 15 September 2011 10:48:05
Thanks willie, for sharing thisBigGrin
S2ksean
#119 Posted : 15 September 2011 11:13:56
Finally got issue three what a nightmare that was the first shop that was surpossed to have if yesterday didn't then went there today and they didn't have it again had to go to another agent to get else it would have took another week still never got it now lol
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#120 Posted : 15 September 2011 11:58:03
For those going the R/C route, some advance thought's on water-sealing the interior of the hull, which is a must if you don't want serious problems!
It's more than likely that the series will go the route of advising a waterproof PVA painted onto the hull interior in conjunction with a bandage (same route as the Bismarck).
The far better route is to the use Graupner's 'Glattfix', which is a specific paint on pore/water sealer that can be applied to the inside and outside of the hull, however this product is now scarce in the UK and the main source being via Germany.
An even better alternative which the R/C pro's use is 'G4 Pond Sealer', which is a polyurethane moisture curing sealer, and is applied in the same manner as polyester resin onto the inside of the hull, but may only need one coat, where as Glattfix requires a number of coats.
G4 can be found at many Garden Centres, usually marketed as a concrete pond sealer, but is now being used to make GRP repairs on full size yachts!
The smallest qty of of G7 is 1kg, and don't forget to add a reinforcing mesh to the inside of the hull (such as plasterboard scrim tape) before sealing it, which is to protect the hull from bumps or "accidents".
56 Pages «<45678>»
This page was generated in 0.143 seconds.
