 Rank: Vice-Master  Groups: Registered
Joined: 20/04/2010 Posts: 545 Points: 1,536 Location: lossiemouth
S2ksean wrote:Cheers tis and mwg be nice when the hull skeleton is done. By the Way does anyone no when that will be? take a look at the buil log the weekly of the bismarck on the net its from the same company if it follows the same rout it will give you an idear when the skeleton is done
Joined: 11/05/2011 Posts: 766 Points: 2,128 Location: Dagenham
Cheers willie il find it and have butchers lol CURRENT BUILDS
Mclaren MP4-23 Ford 1/12 Shelby Mustang GT500 2010 HMS Pandora
S2ksean wrote:Cheers willie il find it and have butchers lol type in build the bismach its the second one down
at about week 11 the bismarck had the planks going on. http://www.buildthebismarck.co.uk/011.htm
then at a guess about issue 16/17 the decking? only a guess mind;)
Cheers zep I'm looking forward ta part 4 now out 2moro CURRENT BUILDS
Is there anyone else having problems getting issues from there newsagents CURRENT BUILDS
 Rank: Pro  Groups: Registered
Joined: 17/03/2010 Posts: 301 Points: 941 Location: fife
yeh, my local wh smith has issue 1 and 2 only (about 10 off each on the shelf), the guy said he had not seen any more so i dont think this is a hit here. current builds
alantait wrote:yeh, my local wh smith has issue 1 and 2 only (about 10 off each on the shelf), the guy said he had not seen any more so i dont think this is a hit here. with hw smith you have to place an order with a down payement of £15 they seem to only hold first two parts try asda they have them
Finally got my hands on the next installment and here it is Issue 4       That's it for this one. the hull is getting there im still bit nervous about the planking side ov things but It will be few weeks yet before I have ta properly start worrying about that. As I said in previous posts this is my first wooden one so all comments welcome. (Yes mr t I changed glues lol) CURRENT BUILDS
this planking is a lot easyer than the victory's
Hi sean. Looking good so far mate. ref the planking side of the model, my first go at planking a model was the hatchette bismarck also done radio controlled. i did not have to many problems with this, following mag instructions. Plus the bismarck was double planked. once it was sanded and a bit of wood filler here and there gave it a very good finish. Hope this helps, Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Joined: 22/03/2010 Posts: 369 Points: 1,150 Location: Broadstairs
willie wrote:super glue gives you one chance the glue i am useing is NO MORE NAILS EXPRESS pva is weather proof gives a strong bond in 5 to ten minutes full cure in 24 houres and its cheaper than super glue I too have bought this in readiness for when I start my build which wont be for a while yet. It states on the label that it is 'weatherproof', which is different from being 'waterproof'. Will have a look at their website just to see. TIS
i have built wooden boats plank and plywood be fore water proof clue came out a good coating of sanding sealer and a few coats of dope never had a plank or ply wood sprange on me, more chance of a plank splitting when it drys out natural
Tiswas wrote:willie wrote:super glue gives you one chance the glue i am useing is NO MORE NAILS EXPRESS pva is weather proof gives a strong bond in 5 to ten minutes full cure in 24 houres and its cheaper than super glue I too have bought this in readiness for when I start my build which wont be for a while yet. It states on the label that it is 'weatherproof', which is different from being 'waterproof'. Will have a look at their website just to see. TIS 'Weatherproof' is fine, because it is on the basis that joints with it are not immersed in water, but in fact are overpainted or sealed which creates the seal; you must use an appropriate water sealer as previously mentioned, end ensure that the hull planks are glued along their full lengths to each other as well as to the framework.
Tomick wrote:Tiswas wrote:willie wrote:super glue gives you one chance the glue i am useing is NO MORE NAILS EXPRESS pva is weather proof gives a strong bond in 5 to ten minutes full cure in 24 houres and its cheaper than super glue I too have bought this in readiness for when I start my build which wont be for a while yet. It states on the label that it is 'weatherproof', which is different from being 'waterproof'. Will have a look at their website just to see. TIS 'Weatherproof' is fine, becasue it is on the basis that joints using it are not immersed in water, but in fact are overpainted or sealed which creates the seal; you must use an appropriate water sealer as previously mentioned, end ensure that the hull planks are glue along their full lengths to each other as well as being glued to the framework. Cheers Mr. T. Will bear that in mind. TIS
remember the glue in the ply wood is not water proof as we are not useing marine ply as said agood coating in and out of sealing or marine varinish or what you wish to use if sailing
Issue 4   Deck supports on  Deck supports off  That's all finished for now just gotta wait yet another week for the next one lol CURRENT BUILDS
Hi Sean great job, we will all help you with the planking, never fear MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Lookin good m8 Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (6)
