Rank: Administration  Groups: Administrator, Administrators, Forum Support Team, Global Forum Support, Global Forum Support Team, Moderator, Official Builds Joined: 24/08/2009 Posts: 1,943 Points: 5,841 Location: UK
Pack 11, Stages 51-55 (shorter and, wellllllll… sweetish…..)
Stage 51; Left side inner trimMount the left inner trim with 3CP screws. Place the roof cover mount into position and secure with 2CP screws. Stage 52 ;Right side inner trimMount the right side same as the left. Install the left front hinge as shown with a GP screw. Stage 53; Boot opening leverJoin the boot lever and the boot hinge with a DP screw. Put the other roof cover on as shown with a GP screw. Stage 54; Front bulkheadMount the lever hinge to the bulkhead with a KP screw from the underside. I decided to put the right hinge cover and the roof cover front hinge together, but I will tape it and the mounting screws to the Caravan top until the other front hinge is to be mounted in the next Pack. Stage 55; Right front seat baseBuild the right seat base as shown. Pack 11 is complete. admin attached the following image(s):
