Joined: 05/05/2014 Posts: 230 Points: 657 Location: Northeast USA
The site download identifies the two front06 and 07 wires protruding in the cowl post areas, but what of the 08 and 09 cables, do they tuck underneath or hang loose out the side ?
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,886 Points: 17,810 Location: ipswich
I did a bit of head-scratching here too and after magnifying one of the instruction picture I found where they go. They route under the floor to the opposite side of the car and exit under the battery box. Roy. roymattblack attached the following image(s):
Joined: 05/03/2017 Posts: 531 Points: 1,710 Location: Midlands, UK
I am also struggling with this, same with the front wires. Currently I have them routed as the images 8n the instructions show, but this can't be right surely as they would get trapped when the bodywork is fitted and they just don't look right loose around the wheel arches Building: Ghostbusters Ecto-1, Ford GT40, Gone in 60 seconds Eleanor mustang, Shelby Cobra Complete: R2D2, Red Bull RB7 RC, Battleship Bismarck, Shelby GT500 'super snake'
I think the actual routing will become much clearer when the body starts to be added and the lights etc are connected.
The thing is, there does seem to be some obvious locations on the interior section where the wires are supposed to come through at the front and rear but the instructions show the wires coming out in the wheel arches. As you say, it could become clearer when the body is fitted in the future but due to how the rear section hinges from the very back, atm I fail to see how the wires are going to be hidden coming from where they are currently and routing to the tail lights. One wire doesn't even seem long enough unless it routes directly over the engine Building: Ghostbusters Ecto-1, Ford GT40, Gone in 60 seconds Eleanor mustang, Shelby Cobra Complete: R2D2, Red Bull RB7 RC, Battleship Bismarck, Shelby GT500 'super snake'
semaj wrote:The thing is, there does seem to be some obvious locations on the interior section where the wires are supposed to come through at the front and rear but the instructions show the wires coming out in the wheel arches. As you say, it could become clearer when the body is fitted in the future but due to how the rear section hinges from the very back, atm I fail to see how the wires are going to be hidden coming from where they are currently and routing to the tail lights. One wire doesn't even seem long enough unless it routes directly over the engine I agree. IF those two wires somehow go to the rear lights, then it's possible that later on, the shorter of the two might have to go back under the floor to come out on the correct side. However, as I mentioned previously we'll find out in due course.
Joined: 31/07/2020 Posts: 22 Points: 72 Location: South Salt Lake City, Utah
Not to worry, if the lights are like the ones on the Lamborghini, they will come with their own pig-tail and connector, plenty of wire (if not excess). All will be revealed in due time. mortyjeff attached the following image(s):
