Another creation of yours I'm going to enjoy following, especially with all the aftermarket parts you're adding.... will be watching..... Regards Alan
Great to see you making a start on this impressive kit Phil. I will definitely be following and commenting throughout the build!
A nice steady start and boy do you have a long way to go 'til the finish, but I've no doubt that the end result will be worth all of that considerable effort over the next few months!
Kev
Per Ardua Ad Astra
Thanks guys and welcome to the journey of the Big Cat Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
So the inside side sponson`s detail`s moulded on and the spare periscopes are the wrong way round ,i`ve marked them in red before i remove them the cables will be replaced with solder and some plastic rod the periscopes and holder are in with the after market ones i got from shapeways also i will replace the cable junction box, also on the rear the lug for the rear idler needs removing tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
A lot of work required there, but it will be worth it in the long run for the accuracy. Keep up the good work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thanks Derek  yes needs a bit of correction Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
so removal of the moulded on periscopes and conduit tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Then filled over tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
New parts added the shapeways spare periscope holders and the electric conduit made from 1mm solder ,plastic rod and the small bracket from some etch brass tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
The electric junction box next this is my first attempt  too big  so started on making another tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
All the pin marks filled and then mr surfacer applied tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Where the interlocking plates meet on the lower hull they are not present so started on replicating them buy first marking them, then cutting them with a pcutter  then i will remove the piece with a micro chisel  add the plate marks  then add weld beads around the edges tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
New arrivals  First 3d printed Extinguisher and Bosch Headlight tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Then a New Engine Hatch which has the internal details  missing from the kit part this is from Shapeways tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Then a New Radio operators seat again from shapeways tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Hi very nice start going to be a long build cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
This is going to be one amazingly detailed King Tiger with all of these extras that you're adding Phil! Your build certainly has my attention and I will be following every step of the way - have fun!
Kev
Per Ardua Ad Astra
Very nicely done Phil. Some very nice detail going on. Mark Regards Markwarren (Mark) Admin
Well thanks guys for looking in  and your comments always appreciate them Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
So the interlocking joints are now complete the rough texture is modelling putty layered on then using a scalpel to make the lines  then the weld beads applied these are from the archer range of decals tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Guest (12)
