The port side gun window had to be masked from both sides - which took me about 1 hour with my eyes getting poorer and poorer!
The "Wongo Wongo" had an additional window spar - which isn`t there with the kit part.
DaDokta attached the following image(s): Greetings, Walter
Next was the first coat of primer, then i painted the bomb bay walls in Vallejo Neutral Grey FS36173.DaDokta attached the following image(s): Greetings, Walter
Hello Walter. Your posting of every detail in this build is far from boring and is a bonus to those who are following your build every step of the way? I for one, as an aviation fan, am enjoying every little detail - keep it up!
If you are having trouble getting the paint in your airbrush to flow properly, that is usually a sign that your paint is too thick? Paint for airbrushing should be thinned about a ration of 50/50 paint to thinners, and sometimes more thinners than paint depending on what brand of paint you are using? Aim for a consistency similar to that of single cream and you won't be far off? Also, with paint of that consistency it is best to keep the air pressure from your compressor at roughly 15-20 psi. Higher than that and too much pressure can actually make the paint dry in the tip of the airbrush before it leaves the nozzle and worse still, if it is travelling too fast between the airbrush and the model surface, it can actually dry slightly as it passes through the air and then you'll end up with quite a 'granular' finish as though you've sprayed the model with wet sand!
So, thin the paint more and keep the pressure down and you'll likely find that the paint will flow at a much more even and constant pressure? Also try painting in several thin coats rather than one thick one and you'll get a much smoother and even finish. Try experimenting and an old model or piece of plastic card until you find the right fluidity of the paint/thinners mix and pressure combination? It can be frustrating learning to use an airbrush, and quite daunting, even confusing, but when mastered you'll never go back to using a paintbrush?!
Hope that helps and keep those updates coming?
Kev
Per Ardua Ad Astra
Thanks again for your advice, Kev.
The neutral grey was a bottle of Vallejos Model Colour Brand - which is in my opinion a little thicker than their Model Air products.
So i think i didn`t mix in enough thinner. In the meantime i sprayed some Vallejo Air colour - which works much better.
Also thanks for the heads-up regarding the air pressure - i worked with a PSI rather at 20 than 15 - will try to turn that down a little bit.Greetings, Walter
Also in the meantime i made a big mistake.
I thought it would be a good idea to prime the PE-parts while still on the fret.
Turned out a very bad idea.
When handling, bending and glueing the parts, all the primer comes off very ugly. So please don`t do that!!
As you can see in my pics, the bomb bay ceiling look horrible at the moment, after attaching many little PE-parts.
Also the first mini-parts managed to get lost :)DaDokta attached the following image(s): Greetings, Walter
I sprayed the rest of the interior walls Dark Dull Green FS 34092.
Went down quite nice compared with the grey colour.DaDokta attached the following image(s): Greetings, Walter
Started with some detailing of the front interior.
Added a "leather"-cushion to the navigator`s seat.
Painted the bomb-sight.DaDokta attached the following image(s): Greetings, Walter
[size=8]Despite a lot of research i couldn`t figure out the exact positioning of the navigator and the bombadier in these early versions of the B-24. But i wasn`t happy with the position of the seat and also with the size and location of the navigator`s table on Eduard`s PE-bulkhead. So i ripped out the seat, cut off the upper part and located everything so, that the navigator would sit in the right height and facing backwards. I hope that´s approximately accurate.[size=8] DaDokta attached the following image(s): Greetings, Walter
Then i cut off the PE-navigator`s table and scratched a new one from some sheet - positioned it in the right height.
Then i tried to immitate the wood grain.
Excellent work, looking really great. Regards Markwarren (Mark) Admin
Thanks Mark,
didn`t have much time this weekend.
I worked on the pilot´s seats - again with some additional leather cushions.
Did some drybrushing.DaDokta attached the following image(s): Greetings, Walter
I attached all the PE-parts of the cockpit. Did some detail painting. Also weathering the front areas of the hull with filters, washes and some sand pigments (as this plane operated in the desert).DaDokta attached the following image(s): Greetings, Walter
Hi Walter, All is looking good, are you happy with your airbrushing looks ok, but I am having trouble opening your last post it may be me. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Walter, all ok with the pictures now must be the forum love your artwork on the controls well done. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Thanks for your comments guys.
Hasn`t this been the problem of this site for many years now, that pics are not shown in a proper way? If i look at my own posts i sometimes see one pic - after a reload an other one, very seldom can i see all pics i posted. And of course i don`t ever know, if other visitors can see what i posted.
This happens of course looking at other build as well.
It´s annoying and a shame that it hasn`t been fixed for years now.Greetings, Walter
Joined: 10/10/2010 Posts: 691 Points: 2,136 Location: Dorset
I find if you hold down the "ctrl" key and press the "R" key the pictures will usually reload. May take several presses Gil Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
Rank: Administration  Groups: Administrator, Administrators, Forum Support Team, Global Forum Support, Global Forum Support Team, Moderator, Official Builds Joined: 24/08/2009 Posts: 1,943 Points: 5,841 Location: UK
Looking great! I built a couple of these when I was a kid. Built may be a bit of a misnomer though. They were glue bombs!
The instrument panel looks amazing!
Cheers,
Here are some updates.
The seats got some seatbelts -which was a very fiddly thing to do!
Also i prepared the front gear bay doors - which didn`t open to the outside at this model, but are sliding to the inside when open.DaDokta attached the following image(s): Greetings, Walter
Guest (9)
