Rank: Administration  Groups: Administrator, Administrators, Forum Support Team, Global Forum Support, Global Forum Support Team, Moderator, Official Builds Joined: 24/08/2009 Posts: 1,943 Points: 5,841 Location: UK
Hi All,
Well while I`ve got the chance, thought I`d post the next Ironman update for Issue 63.
Starting this pack we will construct the Calf Armour Plate for the right leg.
Pic 1 shows the parts supplied.
Pic 2 shows you the orientation of the two parts of the calf hinge and where to secure the hinge together using two LP screws.
Now locate the hinge in its place as shown in Pic 3 and secure it with two EM screws as in Pic 4.
Well that`s all for this issue. Pic 5.
See you soon for the next updates issues 64 - 66.
Regards delboy271155 (Derek) admin attached the following image(s):
Hi All, I`m back
It`s UPDATE time. This one is for issue 64 where the Upper Shin Plate is attached to the right leg, all parts supplied are shown in Pic 1.
Start by removing the paper off one side of a piece of double sided tape the second piece is a spare) and position the tape inside the upper shin plate as shown in Pic 2.
Having removed the other paper from the double sided tape, carefully position the plate into position. Note: care must be taken when fitting the shin plate as the curved sections at the top of the plate have to be flexed outwards to fit the part. Pic 3 shows the location indicated by the yellow lines and Pic 4 the part in place.
Along with the double sided tape the shin plate is fixed using two EM screws as indicated in Pics 5 and 6.
To finish press fit the right and left gold side plates, noting they will only fit on their correct sides. Shown in Pics 7 and 8.
That`s it for this update, but be sure to keep the Hip Joint Cover safe for use in a later stage. Pic 9
Regards delboy271155 (Derek)delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
