Issue 51
Assembling the Rear Floor Pan Secure the rear floor pan using 7 x CM screws as shown in picture 2.
Installing the Resonators Push the left exhaust pipe into the recess in the end of the resonator as shown in pictures 3 and 4. Turn the assembly over and secure the resonator to the rear floor pan using 2 x AP screws, picture 5.
Now do the same to the right resonator.
Picture 6 shows the complete assembly of the resonators.
Installing the Fuel Line Finally, take the fuel line as shown in picture 7 and feed the line from the front of the car through the body to the rear, pictures 8 and 9.
Issue 52
Assembling the Wheel Wells Place the left wheel well in position and secure with 3 x CM screws, picture 2. Attach the right wheel well in the same way as the left wheel well, picture 3.
Picture 4 shows the complete assembly for this issue.
Issue 53
Fitting the Power Switch Take the power switch (52B) and place it into the bracket on the floor pan and secure it with 2 x CM screws as shown in picture 2.
Installing the Battery Box Place the battery box (54A) onto the seat pan, lining up the four screw holes to the posts and secure with 4 x CP screws, picture 3.
Issue 54
Installing the Speaker Place the speaker (54B) into the slot on the floor pan, picture 2. Cover the speaker with the speaker bracket using 2 x CM screws as shown in picture 3.
Installing the Battery Box Cover Carefully turn the assembly over, then insert the two tabs at the bottom of the battery box cover (54A) into the underside of the model and push the top of the cover until it snaps into place, picture 4.
Issue 55
Installing the PCB Place the PCB (55A) on the four-screw post and secure it down with 4 x CP screws. Note: Make sure the “A” faces the front of the car as shown in picture 2.
Place the beacon cable (55C) into the “L” slot as shown in picture 3. Place the switch cable into slot “A”, picture 4, battery box cable into slot “B”, picture 5 and finally the speaker cable into slot “C”, picture 6.
Issue 56
Remote Control Place the buttons (56E) into the front of the remote-control case (56A). This will only fit one way. Note that the tab in the case fits into the button assembly to help its orientation, picture 2. Picture 3 shows how the buttons look from the front.
Now insert the remote-control PCB (56D) as shown in pictures 4 and 5. Snap fit the back of the remote-control case to the front, picture 6.
Finally, insert the battery tray (56C) where you will fit a CR2032 battery (Not Supplied) into the remote as shown in picture 7.
Picture 8 shows the complete assembly for this issue and pack.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
