 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,510 Points: 4,442 Location: Essex
Pack 12 here now Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
Just catching up with your build Steve. It is coming on very nicely, and some very nice detail with this kit. Mark Regards Markwarren (Mark) Admin
Cheers Mark. Here's stage 57 for you. Left rear brakes. I used some extra cable ties to make the brake line tidier along the wishbone. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
WTG Steve.
Looks good.
Regards delboy271155 (Derek) AdminCOME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,886 Points: 17,810 Location: ipswich
It's great seeing another one of these coming together.
Joined: 09/08/2011 Posts: 400 Points: 1,171 Location: Hertfordshire
Hey Steve, looking good! I'm not that far behind you in the way of progress, but good to see another build coming along! How you finding it so far? Having previously built the MP4/4 and MP4/23 certainly finding the glueless build a breath of fresh air! But feel some of these hoses are going to be the death of me The Brawn BuildWentworth Court Dolls HouseThe MP4/4 Build[ulr=http://forum.deagostini.co.uk/default.aspx?g=posts&t=36693]The 97T Build[/url]
Cheers guys. Yes Heinzy, it's a very enjoyable build and i too did the mp4/4 and mp4/23. I think that the more modern builds now are not glued. You end up with a much more sturdy end product. It would be good to see another build as I appear to be the only one doing a diary in the members area Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Steve279021 wrote:Cheers Mark. Here's stage 57 for you. Left rear brakes. I used some extra cable ties to make the brake line tidier along the wishbone.
Great idea. Looking very tidy. Mark Regards Markwarren (Mark) Admin
Cheers Mark. Stage 58, right rear upper arm and shock absorber. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 59 done. Right rear suspension continued. The lower arm front connection was a struggle, you cannot get the driver in straight enough which resulted in a lot of swearing and even a time out😂 but got there eventually🤦♂️ Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 60, right rear hub and drive shaft. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 61, right rear brake disc, caliper and line Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 62, rear end mounted to the chassis. The top 2 engine mounts were a struggle, they just didn't fit very well. I have managed to do the best I can but I'm not that happy with them. Now it's getting heavy! Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Steve279021 wrote:Stage 59 done. Right rear suspension continued. The lower arm front connection was a struggle, you cannot get the driver in straight enough which resulted in a lot of swearing and even a time out😂 but for there eventually🤦♂️ Yeah I found this too, I Tried a shorter screwdriver to start but couldn't get enough grip on it Ended up going to the longest screwdriver I had that fit, happy it's as flush as it can be My next step for Sunday is 62, so looking forward to the marry! The Brawn BuildWentworth Court Dolls HouseThe MP4/4 Build[ulr=http://forum.deagostini.co.uk/default.aspx?g=posts&t=36693]The 97T Build[/url]
The marrying went quite well, it was the upper engine mounts that where difficult and not a great fit Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
That is looking really good Steve, it looks heavy. Mark Regards Markwarren (Mark) Admin
It really is!😲 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
UPDATE:- I'm still waiting for pack 13 as they were out of stock. I believe it's in stock now so hopefully it will be sent out soon. In the meantime pack 14 has just arrived but I can't really do anything with it till I get pack 13. I'll get some pics up when it finally gets here Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Pack 13 is finally here and it came with a cool senna hat too👍. I now have 12 stages to do as pack 14 is here too. Pack 15 will be getting sent soon too so I need to crack on a bit! Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 63. Oil pipes and left side fairing bracket Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
