 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,510 Points: 4,442 Location: Essex
Stage 64. Gear linkage and right side fairing bracket Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
Stage 65. Left and right waste gate pipes. There was 2 radiator pipes included in this stage but are not fitted yet. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Hi Steve,
Good to see you back on this one, its looking good. WTG.
Regards delboy271155 (Derek)COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Cheers Derek, seems like ages since I was last on this Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 66, left turbo and exhaust Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 67, left turbo and oil pipes Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 68. Left turbo inlet. That's pack 13 done now and on to pack 14👍 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Cheers Derek👍. Pack 14 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 69. Left intercooler and chassis cable connectors, 1 connector on each side of the chassis. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 70. Left intercooler fitted Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 71. Left intercooler air duct and name plate fitted Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,886 Points: 17,810 Location: ipswich
Hello Steve. The air duct doesn't look quite correctly fitted. There shouldn't be any of the grille part of the chrome area showing. The parts should be tight together. Probably just a bit of loosening screws and wiggling. roymattblack attached the following image(s):
I'll have a look later. I can't see how it would be adjustable though, both the intercooler and duct screw into fixed holes in the floor but I will investigate further Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
I have had it all off and tried to adjust and there is no adjustment at all, this is how the 2 parts want to sit. Not sure why this is, I can only wait till I get the other side done and then compare it. It looks as though my intercooler is a bit larger then yours maybe. Possibly the production of the parts has changed. I don't know🤷♂️ Edited: I have just watched the deagostini YouTube video on this stage and done a screen shot. Seems to be the same as mine Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 72. Engine ecu Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 73. Left side pod continued and intake grill. Them 2 screws at the bottom of the grill are very tricky😲 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 74. Left radiator. A nice easy stage to finish off pack 14. Waiting for pack 15 now. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Looking good Steve. Nice to see you cracking on with this again. Mark Regards Markwarren (Mark) Admin
Cheers Mark👍 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
