Issue 1
Picture 1 shows the parts for this issue. Take the two side wings (1B & 1C), they are also marked with the letter “R” and “L” on, picture 2. Before we fit these, I opened the tops of the holes first to help guide the screws in place. I found this much easier when fitting these parts. Please do this at your own discretion, pictures 3 and 4.
Position the first wing (1B) on the right side of the windshield aligning the holes, picture 5. Secure this in place using 4 x RJP screws, picture 6. Picture 7 shows it in place.
Do the same with the left side.
Picture 8 shows the complete assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 2
Picture 1 shows the parts for this issue. Take the front fender (2A) and fit the left disc cover (2B). The cover has a pin on its lower end that fits into the hole in the fender. Insert a KP screw to secure this in place, picture 2. Do the same with the right disc cover on the opposite side of the front fender, picture 3.
Now fit the fender mounting discs (2D)as illustrated in picture 4 using an AP screw to secure it in place. Place the other fender mounting disc on the opposite side as before.
