 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,883 Points: 17,801 Location: ipswich
STAGE 33A:
Rear left hub and brakes.
Pic 1: Fix the short suspension arm 33D to the hub 33B as shown using 1 x GM screw.
Pic 2: Fix the longer arm 33C to the hub with 1 x OM screw. The suspension arms will cross over each other – this is correct.
Pic 3: Fit the upper arm 33A as shown and fix with 1 x MM screw.
Pic 4: Fix the disc back plate 33M to the hub using 2 x QM screws.
Pic 5: Locate the disc parts 33I and 33J. 33I will go on top of 33J.
Pic 6: Peel the backing from 33I and stick it to 33J, aligning all the locating pins and holes.
Pic 7: Press-fit the hub 33K onto the assembled disc.
STAGE 33B:
Pic 8: Fit the disc to the main hub as shown using a washer 33O first, then a fixing screw NM.
Pic 9: Fix the caliper 33H to the hub using 2 x CP screws.
Pic 10: Fit the brake tube 33L to the pin on the caliper.
Pic 11: Retrieve the rear axle assembly and fit the hub in place as shown with the upper arms locating in the brackets indicated. Fix the arms using 1 x RM screw in each from the outside.
Pic 12: Fix the bottom of the hub to the suspension arm using 1 x MM screw.
Pic 13: Turn the assembly over and fix the short arm 33D into the bracket 28C indicated using 1 x RM screw. Next, fix the bracket 33P where shown using 1 x BM screw.
Pic 14: Fit the arm 33C into the bracket and fix with 1 x RM screw.
Pic 15: Locate the drive shaft parts33E, 33F and 33N. Fit them together in the order shown.roymattblack attached the following image(s):
STAGE 33C:
Pic 16: Wiggle the assembled shaft in place between the differential and the hub, and then push the rubber parts 33F and 33N over each end to hold it all in place.
Pic 17: Fit the brace 33G in place and fix with 2 x BM screws.
Pic 18: Connect the brake pipes as indicated to the silver connectors.
Pic 19: Retrieve the main car assembly and place it upside down. Lay the assembled rear axle on top, also upside down so you can connect the brake lines inside the transmission tunnel.
Pic 20: Roll the rear axle over, making sure the shock absorbers fit into the locations in the wheel arches.
Pic 21: Detail of the shock absorber location. The other side must be the same.
Pic 22: Fix the rear axle assembly to the car using 3 x BM screws in the locations shown.
Pic 23: Fix the other side in the same way.
Pic 24: Turn the model the right way up and fix the tops of the shock absorbers using 1 x BM screw in each.
Store the model safely.roymattblack attached the following image(s):
STAGE 34:
Right rear wheel.
Pic 1: NOTE: The printed instructions suggest soaking the tyre 34A in hot water to soften it. This is not necessary as the wheel parts fit easily enough with the tyre ‘cold’. Press the wheel rim parts 34B and 34D into the tyre 34A. Note the direction of the tread pattern in relation to the wheel parts. Make sure the screw tabs inside are in line.
Pic 2: View from the other side.
Pic 3: Fit the outer rim 34C in place, again making sure the screw fixing tabs and holes are all in line.
Pic 4: From the other side, fix all the parts together with 5 x ABM screws.
Pic 5: Store all parts safely for now.
STAGE 35:
Rear wheel 2.
Pic 1: NOTE: The printed instructions suggest soaking the tyre 35A in hot water to soften it. This is not necessary as the wheel parts fit easily enough with the tyre ‘cold’. Press the wheel rim parts 35B and 35D into the tyre 35A. Note the direction of the tread pattern in relation to the wheel parts. Make sure the screw tabs inside are in line.
Pic 3: Fit the outer rim 35C in place, again making sure the screw fixing tabs and holes are all in line.
STAGE 36:
Driveshaft.
Pic 1: Fit the universal joint 36F between the yoke on the end of shaft 36D. Fix with 1 x EP screw on each side.
Pic 2: Fit the other shaft part 36E in place as shown and fix with another 2 x EP screws.
Pic 3: Remove the output shaft from the end of the gearbox on the model and fit it the the drive shaft assembly. Fix with 2 x EP screws.
Pic 4: Fit the output shaft back into the gearbox and with the centre of the drive shaft lifted up, fit the other end into the differential. Then lower the drive shaft into place in the middle.
Pic 5: Press-fit the heat shield 36A into place. It will only fit one way.
Pic 6: Fit the heat shield 36C in place as shown. Fix with 2 x IM screws. NOTE – The printed instructions incorrectly show the part to be fitted on the wrong side of the chassis.
Pic 7: Turn the chassis the right way up and fit the fuel inlet in place. Fix it with 2 x IM screws.
STAGE 37:
Fuel tank 1.
Pic 1: Fit the inspection cap 37C to the fuel tank top 37A.
Pic 2: Fix from the other side with 1 x AP screw.
Pic 3: Store the parts safely for now.
STAGE 38:
Exhaust.
Pic 1: Press-fit the sensor 38E into the locating holes in the catalytic converter 38A.
Pic 2: Fit the outer cover 38B as shown and fix from inside with 2 x TP screws.
Pic 3: Fit the heat shield 38D to the exhaust 38C.
Pic 4: Fix from the inside with 1 x AP screw.
Pic 5: Fit the bracket 38F to the end of the catalytic converter as shown and fix with 1 x CP screw.
Pic 6: Press-fit the assembly 36A/E in place as shown.
