Issue 33
The Lower Greave of the Left Knee Place the tab (33B) onto the greave (33A), picture 2.
Turn the assembly over and secure it in place using 3 x DP screws, picture 3.
Picture 4 shows the complete assembly for this issue.
Issue 34
The Upper Greave of the Left Knee Retrieve the lower part of the greave from the last issue and fit the upper part (34A) as shown in picture 2.
Picture 3 shows the complete assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 35
The Left Poleyn Insert the horn (35B) into the skull (35A), picture 2. This is a push fit part. Picture 3 shows the assembly complete.
Retrieve the shin guard assembly from the last issue and place the skull assembly onto the shin guard as illustrated in picture 4.
Issue 36
Body Frame Plate Place the body frame plate (36A) onto the rear hip section you assembled in issue 32, picture 2.
Secure it in place using 6 x MN screws and a washer as shown in picture 3.
That completes the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 37
Lower Back Rear Cover Keep the lower back rear cover (37A) safe to use in the next issue.
Issue 38
Central Back Rear Cover Take part 37A from the previous issue and place the central back cover (38A) onto the upper section of the part 37A, picture 2.
Turn the assembly over and place 3 x MP screws as illustrated in picture 3. Now place 4 x NP screws as shown in picture 4.
Picture 5 shows the complete assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
