 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,883 Points: 17,801 Location: ipswich
STAGE 69:
Ignition coils.
Pic 1: Retrieve the pedal assembly from the previous stage and press-fit the support 69A in place as shown.
Pic 2: Press-fit the support 69B in place as shown.
Pic 3: Retrieve the firewall 68A and fit the pedal assembly in place where indicated. Fix from the other side with 2 x AP screws.
Pic 4: Fit the 2 x coils 69C to the support bracket 69D and fix from behind with 2 x AP screws. The parts will only fit one way.
Pic 5: Fix the assembly to the firewall where shown and fix from behind with 1 x AP screw.
Store safely for now.roymattblack attached the following image(s):
STAGE 70:
Interior floor . Pic 1: Fit the oil pipes 70B in place on the lower left of the floor panel 70A as shown.
Pic 2: Fix from underneath with 2 x AP screws.
Pic 3: Store the parts safely for now.
STAGE 71:
Interior rear.
Pic 1: Fit the duct connector 71B into the hole in the side of the rear panel 71A. You would be advised to use a little cyano adhesive here as the part is a loose fit. Otherwise, store the part until the duct is fitted later.
Pic 2: Retrieve the floor 70A from the previous stage and fit the rear panel as shown. Fix from underneath with 4 x AP screws.
Pic 3: Store the assembly and any unused parts safely for now.
STAGE 72:
Right interior panel.
Pic 1: Retrieve the assembly from the previous stage and fit the side panel 72A in place as shown. Each end will fit with a tab/slot connection where indicated.
Pic 2: Fix the parts with 2 x EP screws.
Pic 3: Store the assembly safely for now.
STAGE 73:
Left interior panel.
Pic 1: Retrieve the assembly from the previous stage and fit the side panel 73A in place as shown. Each end will fit with a tab/slot connection where indicated.
STAGE 74:
Oil tank housing.
Pic 1: Fit the oil duct gasket 74E into the straighter end of the duct 74B.
Pic 2: Fit the other end of the duct onto the post on the duct mount 74A as shown.
Pic 3: Fit the mount to the centre of the rear interior panel as shown and fix with 2 x AP screws from underneath.
Pic 4: Fit the vent fitting 74D into the top of the housing as shown and fix from underneath with 1 x AP screw. The parts fit together with a ridge on the vent stem and a slot in the housing hole.
Pic 5: Fit the assembly in place on the rear interior as shown and fix with 3 x AP screws from underneath.
Pic 6: Store the assembly and unused part safely.roymattblack attached the following image(s):
