Now for something completely different. I have recently built a workshop where I can keep all my laser and 3D printers on hand, rather than spend hours setting everything up when I want to use them. I have also bought some new updated equipment, so I decided to setup this new project to put the equipment to test.
I have designed the Tintin submarine for personal use, so I won’t be making available the model or files because of licencing issues. It is quite a complex model to CAD, and the model will be made with PLA as well as resin for the more detailed parts. I have also made the two figures, Tintin and Snowy to be inside the submarine.
Anyway, I decided to show my progress as a build log, just for something different. The first few pictures are of the files to be printed with a CAD generated picture of what it should look like once complete.
I have made a start over this weekend, printing off the eight body and cockpit parts. I have glued these together ready for sanding and then painting once they are smooth enough.
I have also made the instrument panel. I was going to print this in resin but thought I would test the multi colour option using the PLA printer. Considering how small this was, I thought it came out pretty well.
That’s it for now, more soon.
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,887 Points: 17,813 Location: ipswich
Absolutely amazing stuff Mark. I wish I had gotten into 3D printing years ago. It's amazing what you can do nowadays. Looking forward to seeing this finished.
Thank you Roy
A little more progress. I have printed the main fins that will attach to the body. These will be sanded and painted. There are some smaller fins which will be printed in resin because of their size, picture 1.
I have spent some time sanding, filling and priming the two main body sections to get them smooth ready for the final painting.
The last set of pictures show the two sections painted. The top part painted black gloss and bottom a cottage cream colour. The mouth part will be white. This will be done at a later stage.
I have also started painting the internal cockpit area, still needs a little more finesse, but getting there.
More soon.
Just a little more progress. Printed all the resin parts, including my Tintin and snowy figures. The glass canopy will be made using my vacuum machine, I am buildinmg at the moment. More soon. Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
That's amazing work Mark. I bet it will look fantastic when it's finished.
Getting closer to finishing the submarine part of this built, then onto the base.
In this next part, all the fins have been sanded and painted. I have finished detailing the main body sections, mainly the bottom part putting the smiley face on, scary.
All the parts have now undergone a fine high gloss varnish, which will be left for a week now to harden off, before the final construction. The accelerator lever has now been put into the cockpit after losing the first one in my workshop, never to be seen again.
More soon.
The gloss has had time to dry and harden off for me to start constructing the parts together. Submarine part is pretty much finished apart from the glass cockpit window.
Now onto the base to finish it off.
MarkMarkwarren attached the following image(s): Regards Markwarren (Mark) Admin
That is just mind-bogglingly brilliant. I bet you're chuffed to bits with it.
Roy.
Many thanks Roy.
A little more done to the Tintin project. I have decided on a wooden black gloss base with an aluminium name plate. The plate will be on an angled plate holder fixed to the base, which will be 3D printed.
I designed the name plate graphics from the book illustration, I then laser engraved it onto an aluminium plate and cut to size.
Just a couple of holes to be made in the base to support the stand for the model.
More soon.
Just 3D printed the plaque resting plate which you can see in the first two pictures. I then drilled holes in the base for the supports.
The last two pictures shows the completed base. All I need to finish off the model is the clear glass screen for the cockpit canopy.
Happy modelling.
That's just about unbelievable. Superb work there Mark.
Roy.
Thanks again Roy.
Well I finally got the glass in the canopy fitted. I 3D printed the glass template in PLA then placed it into my vacuum press. I used 0.5mm plastic sheet to mould it in shape.
Very pleased with how it turned out. Once the sheet had been heated to the correct temperature, it took seconds to make. The first picture is the glass set into the canopy.
And that is it, all finished.
The last two pictures show it complete. I really enjoyed designing and making this.
It really is astounding work.
