Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,335 Points: 22,312 Location: Northamptonshire, England
Issue 57
The Upper Structure of the Left Arm Place the joint assembly from the previous issue and place it into the arm structure, securing it in place using 4 x LP screws, pictures 2 and 3.
Issue 58
The Left Arm Joint Place the upper arm joint onto the previous assembly securing it in place using 2 x KP screws, pictures 2 and 3.
Tip: Before we start with the next section, I would recommend using a pair of sturdy pliers to compress the spring. This will make it easier to fit into the part into the housing, picture 4.
Slide the spring onto the rod and insert the assembly into the base joint as shown in picture 5. Take the connection place and attach it to the previous assembly, then insert the pin to hold it in place, pictures 6 and 7.
Attach the base cover to close the assembly using the nut and 2 x HM screws as shown in picture 8. Use the wrench that was provided in issue 7 to tighten the nut.
Finally, secure the assembly to the arm assembly using 4 x SP screws, picture 9. Note, it should only fit one way.
Picture 10 shows the complete assembly for this issue.
Issue 59
The Right Shoulder Joint Insert the shaft into the base, pictures 2 and 3. Place one of the springs into the spring stop, then place the assembly into the base at the end where you fed the joint shaft in, pictures 4 and 5. Cover the end of the base with the shaft and spring in place with the shoulder joint cover and secure it in place using 2 x “OM” screws, picture 6.
Tip: As in the previous issue, I would recommend using a pair of sturdy pliers to compress the spring. This will make it easier to fit into the part into the housing.
Slide the spring onto the rod and insert the assembly into the base joint as shown in picture 7. Take the connection place and attach it to the previous assembly, then insert the pin to hold it in place, picture 8.
Attach the base cover to close the assembly using the nut and 2 x HM screws as shown in picture 9. Use the wrench that was provided in issue 7 to tighten the nut.
Place the assembly onto the body frame as shown in picture 10, securing it in place using 4 x EM screws, picture 11.
Now place the assembly from issue 58 onto the other side of the body frame as illustrated in picture 12.
Picture 13 shows the complete assembly for this issue.
Issue 60
The Upper Back Cover Retrieve the assembly from issue 38. Start by unscrewing the for screws as shown in pictures 2 and 3.
Place the upper back part inside the back assembly and secure it in place using 5 x RP screws, pictures 4 and 5.
Attach the new assembly to the body frame using 18 x RP screws as illustrated in picture 6.
Picture 7 shows the complete assembly for this issue.
Issue 61
The Upper Torso Cover Retrieve the assembly from issue 48, picture 2.
Place the upper torso on the front of the assembly from issue 48 and secure using 5 x RP screws, picture 3.
Place the front of the torso onto the body frame and secure it in place using 12 x LP screws as shown in pictures 4 and 5.
Picture 6 shows the complete assembly for this issue.
Issue 62
The Left Forearm Place the forward onto the elbow joint using 2 x KP screws as shown in pictures 2 and 3.
Picture 4 shows the complete assembly for this issue.
