 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,883 Points: 17,801 Location: ipswich
STAGE 33:
Right front lights.
Pic 1: Retrieve the right front wing 32C and fit the light cover 33-2. It will only fit one way.
The next steps are in a different order to the printed instructions to make assembly a lot easier.
Pic 2: Bend the LED end of one of the cables 33-5 at a dog-leg 90 degree shape as shown.
Pic 3: Press the LED into the holder 33-1 as shown, with the wires located in the lower slot.
Pic 4: Repeat with the other 2 x LED – 33-5.
Pic 5: Press-fit the LED holders 33-4 (shorter) and 2 x 33-3 (longer) in place where indicated.
Pic 6: Fit the assembly inside the front wing and fix with 1 x G screw.
Store safely for now.roymattblack attached the following image(s):
STAGE 34:
Left front wheel 1.
Pic 1: Wheel part 34-2 will fit inside part 34-1.
Pic 2: Fit the parts together and fix with 4 x D screws.
STAGE 35:
Left front wheel 2.
Pic 1: The wheel from the previous stage will fit inside the tyre 35-1. Make sure you insert the wheel the correct way up. You will very likely need to soak the tyre in hot water for several minutes before fitting it to the wheel. It is a VERY tight fit. Dry the tyre thoroughly first and take care when using hot water.
Pic 2: Parts assembled.
Pic 3: Fit the outer tyre 35-2 and fix with 4 x D screws.
Pic 4: Store the wheel safely.
STAGE 36:
Rear hood.
Pic 1: Locate the hood 36-1 and the hinges 36-2 and 36-3. Note that the side hinge pins face out.
Pic 2: Fix the hinges in place with 1 x K screw in each.
Pic 3: Store safely for now.
STAGE 37:
Rear hood 2.
Pic 1: Locate the vents 37-2 and 37-3 and the grilles 2 x 37-4.
Pic 2: Press the grilles onto the backs of the vent panels as shown.
Pic 3: Retrieve the rear panel and press-fit the vents in place as shown. They will only fit one way.
Pic 4: Fit the rear support 37-1 in place and fix with 2 x A screws.
Pic 5: Store safely for now.
STAGE 38:
Left side skirt.
Pic 1: Press-fit the detail parts 38-3 and 38-4 into place on the inside of the skirt 38-1.
Pic 2: Fix the connector 38-2 to the outside of the skirt with 1 x D screw.
