 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,510 Points: 4,442 Location: Essex
Stage 26. Right front brake disc surround and caliper. That's pack 6 finished. Waiting for pack 7 now Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
Pack 7 here now but annoyingly it's missing stage 32 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 27. Front right wheel cover Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 28 and 29. I done these 2 stages together as i didn't like the order the wheel tyre assembly was put together. I wanted to fit the tyre before fitting the wheel cover. Note, the tyre is really solid so I put it in boiling water for 30 seconds to soften it up. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 30. Brake disc deflectors and fitting the front wheels. I have decided to leave the wheels on. I know a lot of people don't and it does make it heavy but the way i see it, there are a few delicate plastic pieces installed on the hub areas and having the wheels on will protect them from damage. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 31, halo support and external push buttons. That's, what i have of, pack 7 done. Waiting for pack 8 now and hopefully stage 32. The advantage of not having stage 32 is that I am able to put the body section back in is plastic shipping case for now. Every cloud!😂 Does anyone know why the halo support has 2 screw holes in but the instructions say to only put 1 in? Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Just received pack 8 and it had stage 32 in👍 Right side sidepod front Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Pack 8 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 33, left side pod front and attaching the front suspension to the front body section Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 34. Steering shaft, cockpit surround, chassis support, steering support and windscreen Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 35. Steering wheel and chassis cover plate. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 36. Left side pod structural panel Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 37. Left radiator. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 38. Left radiator continued. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Well, them last 3 stages didn't take long! That's pack 8 completed now. Waiting for pack 9👍 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Well, after a 4 month wait pack 9 is finally here! Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Here we go then. Stage 39, left radiator and side pod assembly Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 40. More cooling pipes for the left hand assembly. Starting on the right side assembly. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 41, right side radiator Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 42, right hand side radiator assembly Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
