 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,883 Points: 17,801 Location: ipswich
STAGE 75:
NOS bottles.
Pic 1: Fit the nozzles 75F into the bottle halves 75A as shown.
Pic 2: Fix the bottle bases 75B using 2 x AP screws in each.
Pic 3: Stick the NOS labels 75E to the tops of the bottles.
Pic 4: Fit the support legs 75D and 75E to the bottles as shown. Make sure they are fitted the right way round as shown in the picture.
Pic 5: Stick the gauge labels 75I to the face of the gauges 75G, then fit the gauges to the nozzles on each bottle.
Pic 6: Fit the shut off valves 75H to each bottle.
Pic 7: Fit the bottles to the interior assembly as shown.
Pic 8: Fix from underneath with 2 x AP screws in each bottle.
STAGE 76:
Audio system.
Pic 1: Stick the display screen 76J to the face of the display unit 76B as shown.
Pic 2: Fix the assembly to the housing 76A with 1 x CP screw inside.
Pic 3: Fit the unit to the car interior as shown. The NOS bottles have been removed to make the fitting clearer.
Pic 4: Fix from underneath with 2 x CP screws.
Pic 5: Fit the 2 x subwhoofer 76I speakers in place where indicated.
Pic 6: Fix from underneath with 4 x CP screws.
Pic 7: Fix the left shock absorber strut parts 76C, 76D and 76E together as shown. All parts are marked ‘L’.
Pic 8: Fix the right shock absorber strut parts 76F, 76G and 76H together as shown. All parts are marked ‘R’.
Pic 9: Fit the right assembly to the car floor where shown. It will only fit one way.
Pic 10: Fit the left assembly in the same way.
Pic 11: Fix from underneath with 2 x CP screws in each.
Store safely for now.roymattblack attached the following image(s):
STAGE 77:
Roll bar.
Pic 1: Press-fit the lower supports 77D and 77E onto the ends of the roll bar 77A as shown. The parts are marked L and R.
Pic 2: Fit the roll bar onto the car floor as shown and fix with 2 x CP screws from underneath.
Pic 3: Fit the left brace 77B and fix with 1 x CP screw underneath and 1 x AP screw through the roll bar.
Pic 4: Fit the right brace 77C in the same way.
Pic 5: Tilt the seat forward and wrap one of the belts around the lower roll bar strut from underneath as shown, then feed the end of the strap through the buckle to keep it in place. Be patient as this is very fiddly.
Pic 6: Repeat with the other three straps.
STAGE 78:
Dashboard 1.
Pic 1: Fit the air vent 78B into the dashboard as shown and fix with 2 x CP screws. The part has been highlighted in grey for clarity.
Pic 2: Fit the air vent 78C into the dashboard as shown and fix with 1 x CP screw. The part has been highlighted in grey for clarity.
Pic 3: Fix the dashboard mounting bracket 78D as shown using 1 x IP screw.
Pic 4: Store safely for now.roymattblack attached the following image(s):
STAGE 79A:
Dashboard 2.
Pic 1: Retrieve the dashboard from the previous stage and press-fit the upper visor 79A in place as shown.
Pic 2: Fit the 3 x lenses – 2 x 79D and 1 x 79E – into the surround 79F. 79E goes in the centre.
Pic 3: Fit the gauge strip 79C in place.
Pic 4: Turn the dashboard face down and fit the gauge assembly in place as show. Then fit the rear panel 79B on top and fix everything with 2 x CP screws.
Pic 5: Retrieve the LED strip 42B and fit it in place as shown. Fix with 2 x DP screws.
Pic 6: Locate the gauge parts 79G, 79H and 79I.
Pic 7: Fit the parts together as shown.roymattblack attached the following image(s):
STAGE 79B:
Pic 8: Fit the lens 79M into the tube 79K and then fit to the mount 79J. The parts will only fit one way.
Pic 9: Fit the gauge to the assembly as shown.
Pic 10: Fit the assembly into the upper hole in the dashboard where shown.
Pic 11: Assemble two warning lights using parts 79L, 79N and 79M.
Pic 12: Fit the lights to the lower two holes on the dashboard as shown.
Pic 13: Fit the two components 79Q and 79R where indicated.
Pic 14: Fit the lighter 79P into the mount 79O.
Pic 15: Press-fit the assembly into the rear of the dashboard where shown.
Pic 16: Store safely for now.roymattblack attached the following image(s):
STAGE 80A:
Dashboard 3.
Pic 1: Fit the monitor sticker 80J to the screen 8OB.
Pic 2: Fix the screen to the airbag panel 80A using 2 x AP screws from behind.
Pic 3: Press-fit the air vents 80C in place. They will only fit one way.
Pic 4: Fix the assembly into the rear of the dashboard using 2 x CP screws.
Pic 5: Fit a display sticker 80I to the DVD unit 80G. Then fit two small self-adhesive strips 80K to each side of the display. Finally stick the clear screen 80H in place.
Pic 6: Fit the unit to the dashboard as shown and fix with 2 x DP screws from behind.roymattblack attached the following image(s):
STAGE 80B:
Pic 7: Fit the control unit 80F inside the glove box lid 80E as shown.
Pic 8: Retrieve the dashboard and fit the assembly in place in the opening with the hinges locating in the recesses.
Pic 9: Fix the glove box 80D in place with 2 x CP screws.
Pic 10: Using a piece of tape 22D, fix the dashboard wire in place where indicated.
Pic 11: Store safely for now.
