Issue 69
Right Leg
Picture 1 shows the contents of this issue. Slot the right an ankle friction disc into the friction disc base, then secure it in place using four type J screws, picture 2.
Next, slot the right ankle mobile bar on the top of the assembly and secure it in place using four type O screws, pictures 3 and 4.
Retrieve the right leg assembly you've been building in previous issues and attach the ankle joint you've built in this issue as shown in picture 5. Turn the assembly over and secure it in place using two type M screws picture 6.
That completes the assembly for this stage.
Issue 70
Right Leg
Picture 1 shows the contents of this issue Retrieve the right leg assembly you've been working on in previous issues and fit the right shin over the front of the right knee as shown in picture 2. Secure the assembly in place using two type F screws to the top and two type M screws to the bottom.
Fit the right kneecap onto the pegs on the knee joint in the central part of the leg, as shown in picture 3.
Place the two friction spacer washers on top of the end of the ankle joint that sticks out from the bottom of the legs. Now slot the boot hinge bracket into the part where you place the washers as illustrated in picture 4. Rest the screw washer inside the bracket you fitted in the previous step, as shown in picture 5. Now secure this entire ankle assembly using the type N screw, picture 6.
Issue 71
Left Leg
Insert the friction disc into the left recess in the knee base and secure it using 4 x type V screws, picture 1.
Slot the mobile knee bar onto the friction disc and secure in place using 4 x W screws as shown in picture 2.
Picture 3 shows the assembly stage complete for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 72
Left Leg
Picture 1 shows the contents of this issue Retrieve the assembly from the last issue and insert the friction disc into the right recess and secure in place using 4 x V screws, picture 2.
Slot the mobile knee bar onto the friction disc and secure it in place using 4 x W screws, picture 3.
Place the knee cover over the assembly, picture 4 and turn the assembly over and place 3 x F screws into the holes to secure it in place, picture 5.
Issue 73
Left Leg
Picture 1 shows the contents of this issue Retrieve the previous assembly and slot one of the support bases onto the mobile bar at the base of the knee, as shown in picture 2. Turn the assembly over and secure it in place using 2F type screws picture 3.
Now place the other support bar over the top and using two F type screws on either side secure the two parts together, pictures 4 and 5.
Place the assembly in the rear cover of the left thigh. And secure it in place using two type F screws, picture 6, 7 and 8.
Picture 9 shows the assembly stage complete for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 74
Left Leg
Picture 1 shows the contents of this issue Slot the friction disc into the support base for the left thigh bar and secure it in place using four type Z screws, picture 2.
Place the mobile bar of the left thigh on top of the friction disc and secure it in place using three type Q screws, picture 3.
