Issue 124
Rear Window Place the rear window into the back of the body in preparation for the next stage, picture 2.
That completes the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 125
Rear Window Frame Place the rear window frame onto the window, picture 2. Place the antenna base into the slot on the right wing, picture 3, turning it over and securing it in place using a PS05 screw, picture 4.
Whilst the assembly is in the upside down position, secure the window and frame by using 8 x PS12 screws, picture 5.
Issue 126
Door Trims Place the right upper door trim on the outside of the door opening, pressing home the four pins, picture 1. Secure it in place using 4 x PS27 screws from the inside, picture 2. Do the same with the left door trim.
Place the right doorstep trim on the lower section of the door opening and press in place, picture 3. Do the same with the left door trim.
Issue 127
Front roof interior and sun visors Identify the right and left sun visors, they will have an “R” and “L” on the back of them. Insert the outer pin into the socket and press fit the other inner pin in place on the roof interior.
Issue 128
Rear roof interior and rear view mirror Attach the rear-view mirror mount to the mirror holder, picture 2. Place the adhesive mirror base inside the mirror holder, picture 3, then attach the mirror, picture 4.
Place the mirror assembly into the notch on the front roof interior, picture 5, turning it over and securing it in place using a PS05 screw, picture 6.
Attach both the front and rear roof lining together using 3 x PS05 screws as shown in picture 7.
Now place the roof interior inside the body and secure it in place using 4 x DS02 screws, picture 8.
Finally, cover the screws using the caps provided, picture 9.
