Issue 93
Trunk Lock & Taillight Panel Picture 1 show the parts for this issue. Install the hinge of the fuel cap into the cap surround and using the hinge bracket, secure it in place using a G screw, pictures 2 and 3. Pictures 4 and 5 show the assembly complete.
Next, we fit the trunk lock cylinder. This is quite fiddly and will only fit one way. I recommend using a small wooden stick and a small piece of Blu-tack to guide the part in place, pictures 6 and 7.
Fit the fuel cap assembly as shown in pictures 8 and 9 using a G type screw. Picture 10 shows the parts in place.
Finally, fit the left and right tail lights from the last issue, picture 11.
Picture 12 shows the assembly complete for this issue.
Issue 94
Bumper Bracket Picture 1 show the parts for this issue. Install the bumper bracket to the rear of the car and secure it in place using 5 x F type screws as shown in picture 2.
Issue 95
Taillights Picture 1 show the parts for this issue. Retrieve the body assembly and with it turned over fit the left and right taillight housing parts using 2 x H screws for each part, picture 2.
Secure the trunk lock with a G type screw as shown in pictures 3 and 4. Next, place both the light diffusers into the housings, picture 5.
Attach the rear light panel as illustrated in picture 6, securing it in place using 2 x C screws, picture 7.
To finish of this assembly, turn the body over again and fit the rear bumper using 4 x C screws as illustrated in picture 8.
Picture 9 shows the assembly complete for this issue.
Issue 96
Right Front Fender Picture 1 show the parts for this issue. Before attaching the front fender, make sure the cable is place in the recess as illustrated in picture 2 so they do not get trapped when attaching the part.
Secure the front fender using 2 x P screws as shown in picture 3.
Picture 4 shows the assembly complete for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 97
Left Front Fender Start by attaching the front panel assembly to the left front fender using 2 x P screws, picture 1.
Turn the car body over and attach the left fender to the body, picture 2, then attach the other side of the panel assembly to the right fender, picture 3.
Fit the front grill support onto the front panel and secure it in place using 4 x F screws, picture 4.
Picture 5 shows the assembly complete for this issue.
Issue 98
Right Rear Window Picture 1 show the parts for this issue. Remove the backing from the two self-adhesive strips on the air intake, picture 2. Attach the air intake to the body as shown in picture 3.
Fit the right-hand badge using a D type screw as shown in pictures 4 and 5.
Fit the rear window, then fit the window frame which hold everything into position, pictures 6 and 7.
Picture 8 shows the assembly complete for this issue.
