Ferrari F1-2000 Official build Stages 39 - 44 Options
#1 Posted : 17 November 2026 11:06:58
STAGE 39:
Left rear suspension 2.
Pic 1: Fit parts 39A and 39C together as shown.
Note the orientation of the bracket on 39C highlighted in yellow.
Pic 2: Fix 39B in place with 1 x NP screw.
Pic 3: Fix the assembly to the bracket on the gearbox part from the previous stage using 1 x AM screw.
Pic 4: View from the other side.
Pic 5: Fit the hose 39D to the two pins as indicated.
Store safely for now.
#2 Posted : 18 November 2026 13:14:55
STAGE 40:
Left rear suspension.
Pic 1: Fix the axle support 40C into the gearbox part 37A as shown using 2 x QM screws.
Pic 2: Retrieve the engine and place it upside down in the position shown.
Pic 3: Fix the gearbox assembly in place using 1 x CM screw.
Pic 4: Slide the boot 40B over the shaft 40A.
Pic 5: Fit the shaft into the gearbox.
#3 Posted : 19 November 2026 14:27:30
STAGE 41:
Gearbox 2.
Pic 1: Fix the bracket 41C to the Gearbox part 41A with 1 x QM screw.
Pic 2: Fix the junction box 41B in place where shown with 1 x AP screw from behind.
#4 Posted : 20 November 2026 17:36:11
STAGE 42:
Rear right suspension.
Pic 1: Retrieve the gearbox part from the previous stage and fix the bracket 42B with 2 x QM screws.
Pic 2: Fix the bracket 42C with 2 x QM screws.
Pic 3: Fix the bracket 42D with 2 x QM screws.
Pic 4: Fit the arm 42A in place as shown and fix with 2 x BM screws.
The arm should be able to move up and down slightly.
#5 Posted : 24 November 2026 18:55:25
STAGE 43:
Right rear suspension 2.
Pic 1: Fit parts 43A and 43C together as shown.
Note the orientation of the bracket on 43C.
Pic 2: Fix 43B in place with 1 x NP screw.
Pic 4: Fit the hose 43D to the two pins as indicated.
Pic 5: Store safely for now.
#6 Posted : 25 November 2026 12:19:14
STAGE 44:
Right rear driveshaft.
Pic 1: Fix the bracket 44C into the gearbox part 41A using 2 x QM screws.
Pic 2: Retrieve the previously assembled circuit board and disconnect wire ā€˜C’.
Pic 3: Retrieve the engine assembly and fit the wire in place as shown noting the yellow highlighted section, and the red circle where the LED exits.
Allow approx. 40mm of wire at the rear.
Pic 4: Assemble the drive shaft parts 44A and 44B as shown.
Pic 5: Fit the driveshaft into the gearbox where indicated.
Pic 6: Fix the assembly in place using 2 x EM screws where shown.
Make sure the LED wire exits the gearbox where highlighted in yellow.
This page was generated in 0.056 seconds.
