Issue 99
Left Rear Window Picture 1 show the parts for this issue. Remove the backing from the two self-adhesive strips on the air intake, picture 2. Attach the air intake to the body as shown in picture 3.
Fit the left-hand badge using a D type screw as shown in pictures 4 and 5.
Fit the rear window, then fit the window frame which hold everything into position, pictures 6 and 7.
Issue 100
Rear Window Picture 1 show the parts for this issue. To begin, turn the body over and fit the rear window and secure it in place using 4 x E type screws as shown in picture 2.
Turn the body back over and fit the rear window trim panel as shown in picture 3. Once again, turn the body over and secure it in place using 2 x C type screws as shown in picture 4.
That completes the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
