 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,888 Points: 17,816 Location: ipswich
STAGE 147A:
Emergency time circuits.
Pic 1: Assemble the parts 147E and 147F as shown, fixing them with 2 x CP screws. Make two sets the same.
Pic 2: Fit the 2 x brackets 147G in the time circuit box where indicated.
Pic 3: Fix the assemblies from step 1 into the box as shown using 1 x AP screw from underneath in each.
Pic 4: Assemble parts 147H, 147I and 147M as shown.
Pic 5: Fix the assembly into the box where shown using 2 x QP screws.
STAGE 147B:
Pic 6: Assemble parts 147J, 147K, 147L, 147M and 147N in the order shown.
Pic 7: Fix the assembly into the box where shown using 2 x QP screws.
Pic 8: Fit the parts 147C and 147D together as indicated and fix from below with 1 x AP screw.
Pic 9: Fix the assembly into the box as shown using 1 x RP screw from underneath.
Pic 10: Press-fit parts 147B onto the base 147A. They will only fit one way.
Pic 11: Fix the assembly into the box with 2 x AP screws from underneath.
Store safely for now.
STAGE 148:
More railway.
Pic 1: Fix parts 148A and 148B together with 2 x EP screws. Fix the connectors 144C and 148C to each side of the sleeper with 1 x EP screw in each. Do the same at the other end of the assembly.
Pic 2: Retrieve the assembled track and lay it upside down. Fix the new assembly in place as shown using 2 x EP screws.
Pic 3: With the track the right way up, fix the 2 x chairs 145B in place using 2 x EP screws in each.
