 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,888 Points: 17,816 Location: ipswich
STAGE 3A:
Right hand.
Pic 1: Fix the wrist piece A11 into the rear of the hand M10 with 2 x MS4 screws. It will only fit correctly one way.
Pic 2: Attach the thumb M12 with 1 x MS4 screw.
Pic 3: Fix the finger bracket A10 to the inner hand A14 with 2 x AS5 screws.
Pic 4: Fix the assembly to the rear of the hand with 4 x MS4 screws.
Pic 5: Fit the One ring over the finger.roymattblack attached the following image(s):
STAGE 3B:
Pic 6: Fix the end of the finger M9 in place with 1 x MS4 screw.
Pic 7: Fit the magnetic screw cover A9 in place.
Pic 8: Fix the back of the gauntlet M11 in place with 2 x AS5 screws.
Pic 9: Fit the magnetic cover M8 in place and press-fit A15 over the lower screw.
Pic 10: Press-fit the thumb cover A12 in place.
Pic 11: Store everything safely for now.
STAGE 4:
The mace.
Pic 1: Assemble the handle parts MS13 and MS15 as shown and fix with 1 x MS4 screw.
Pic 2: Press-fit the cover A16 over the screw.
Pic 3: Fit the mace head M14 in place.
Store safely for now.
STAGE 5:
The mace 2.
Pic 1: Retrieve the mace from the previous stage and fit the lower shaft M17 as shown. It will only fit one way. Fix with 1 x MS4 screw.
Pic 2: Press-fit the screw cover A17 in place. It will only fit one way.
Pic 3: Store everything safely for now.roymattblack attached the following image(s):
