Good tip Mike definitely use it in future Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
 Rank: Vice-Master  Groups: Registered
Joined: 20/04/2010 Posts: 545 Points: 1,536 Location: lossiemouth
i know you like your balsa fillings but have you ever came across an other type of filler , it came once with a french frigget i did for the bow and stern its easer than balsa wood to shape and sand, cant remember the name of it, it look like compress brown saw dust
No, I have not come across what you mention. MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE ONE PLANKING Hi Team the next thing to do is fit the planks, Port and Starboard (left and Right) I have used pins at the Bow and Stern, but I will take them out when the glue is dry, I do not like to use permanent trenails in any hull that I plank, if the planks are bent naturely then adhesive is sufficient in my opinion, whether the ship be the Victory or this small Longboat.:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE ONE PLANKING I have now soaked 4 planks 2 for Port 2 Starboard It is important to plank both sides equally so that the Hull does not twist. When I naturelly bend more than one plank at a time I fit kitchen towel between the clamps and the wet planks, this soaks up moisture and protects the wood from clamp marks. I will now leave these planks about 12 hours to dry, then I will shape and fit them and glue in place. (AT THE MOMENT THE PLANKS ARE NOT PERMANENTLY FITTED) MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE ONE PLANKING The hull looks like this at the moment (looks like its just been to A&E) Comments welcome  :- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE ONE PLANKING Now the Planks are dry, you can see they are perfectly formed to the shape of the Hull ready for trimming and fitting.This way of bending planks takes longer, but in my opinion is more rewarding. Comments welcome MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE ONE PLANKING Hi team this is the latest update to the build, I have now fitted 3 planks on each side of the longboat,these are the photos of that build:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE ONE PLANKING The next job is to fit the Gardboard planks to the keel, but thats for next time. This is how she looks at the moment,comments welcome  :- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE ONE PLANKING I have now soaked and fitted wet the gardboard planks (exactly the same procedure we all used on the Victory build)I have used pins to hold them in place untill the planks are dry, then I will trim and fit them tomorrow:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE ONE PLANKING I have left a 4mm space between the planks to take the Keel, stem and stern post, thats all for now comments as usual are welcome MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE ONE PLANKING I decided to soak another 2 planks and while wet place and shape them along side the Gardboard planks. All 4 planks in this area have not been fitted permanently this will be done when they are dried to shape:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE ONE PLANKING the space in the stern will be filled by a steeler plank (both sides) Comments welcome MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thanks again Kev for the encouragement, as you know modelling is a journey not a destination, I also say to people, there is no such thing as failure only outcomes and results, this is a very slow process but very rewarding MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Many a true word in that sentence mate !!  Kev.
Joined: 11/05/2011 Posts: 766 Points: 2,128 Location: Dagenham
Could u not use something like a hairdryer for instants to dry the planks off quicker. Looking nice by the way CURRENT BUILDS
Mclaren MP4-23 Ford 1/12 Shelby Mustang GT500 2010 HMS Pandora
Hi Sean yes you can use a hair dryer and people do with good results, as people use plank benders (the heat type)and soldering irons etc. but I prefer to soak the timber then let it dry and form naturaly (with a little help from my clamps an pins)its slow but I believe it works better for me, other people will have a system that works for them,and then there will be new people, who if they see examples of all the different ways of bending planks, will find one that thy feel comfortable with. I am glad you asked the question, and I hope my answer is of help to you MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Cheers for clearing that up CURRENT BUILDS
ISSUE ONE PLANKING Well the planks are dry and well formed here they are:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Guest (6)
