32 Pages «<45678>»
Ger C
#101 Posted : 04 February 2012 01:23:49
Planking came out very well, am going to start mine tomorrow, hope that it looks as good as yours,LOL
#102 Posted : 04 February 2012 10:40:48
BigGrin Thanks very much for the comment Ger il be posting more pics of the hull sanded back shortly
#103 Posted : 04 February 2012 14:54:29
the rough sanding of the hull is more or less compleat just some finishing off around the stern[only just glued it onLOL ]and bow,still needs a good final sanding but cant do that till i get the measurments to go on the base [next issue i think].As ussual all comments are welcome
#104 Posted : 04 February 2012 15:05:54
BigGrin Thought i would include here a few pics of the internal structure after planking as this might benefit /help novices doing there 1st or 2nd builds, as a guide on how it should look inside [note this is before iv epoxyed the inside of the model]
Smuggler
#105 Posted : 04 February 2012 16:35:34
Looks great,but can you tell me what type of epoxy you used on the inside of the hull?
I have never tried a ship like thisBlushing and as such will need advice from people like yourself and Mr T.
I smile because i have NO IDEA whats going on :)
#106 Posted : 04 February 2012 17:31:17
BigGrin Hi Smuggler
The epoxy i use is by Pacer[there are other brands on the market]and comes in two 6oz bottles,i find it mixes easily and has a good coverage, 60ml did the inside of the Yamato,you will also need some mixing cups and wooden spatulas but any old wood will do as long as its clean and last of all the cheapest brushes u can buy as they are of no use once the epoxys gone off, quarter to half inch wide is ok . Also it sands easily and can be painted over,im still contemplating using this as a base coat on the outer hull before painting as it will give a smooth glass like finish that when painted will more resemble a steel hull. Hope this helpsCool
Smuggler
#107 Posted : 04 February 2012 19:08:18
Thanks for the info, and the suggestion of using it on the outside is a stroke of geniusThumpUp , i was pulling my hair out ( Whats left of itLOL ), trying to work out how to smooth the ouer hull properly so i can paint it.
#108 Posted : 04 February 2012 19:22:20
BigGrin No probs Smuggler just remenber although the resin will have a semi self leveling effect so small blemishes will be filled by it ,but major craters [not saying you have anyLOL ]will have to be filled.As with all jobs a good basic finish to the hull will give a smooth finish when the epoxy goes on
PS it will probablly take at least 2/3 coats of epoxy and a good sanding back to get the desired finish and a light sanding after as a key for the paint
#109 Posted : 04 February 2012 19:25:12
BigGrin heres the stern finished to a rough sanding and thats it for this month,as always all comments are appreciated/welcome
#110 Posted : 04 February 2012 19:31:14
lOOKS GREAT!!Cool
J
#111 Posted : 04 February 2012 19:55:54
BigGrin Thanks JaseThumpUp Cool
#112 Posted : 23 February 2012 20:17:33
decided to epoxy coat the inner hull as it will be more difficult to get to all the nooks and crannys soon as more things are added to the hull. As usual all comments are welcome
#113 Posted : 23 February 2012 20:57:04
Good stuff AndyBigGrin Build is looking greatBigGrin Regards MikeBigGrin
#114 Posted : 23 February 2012 23:13:53
BigGrin Thanks for the nice comments Mike ThumpUp
Smuggler
#115 Posted : 24 February 2012 00:03:33
Looking goodThumpUp and thanks for the resin info ( No craters on my model..........yetLOL )
#116 Posted : 24 February 2012 16:41:13
BigGrin Thanks Smuggler and n/p on the resin it wouldnt be a forum if we didnt help each other out on diffrent ways of doing stuff.ThumpUp Il deffinatly be using resin on the outer hull to get the effect i want but contemplating on wether to use nylon aswell [ its very light nylon only 1oz per square meter],it wont really add strength but when applied corectly it will give a uniform effect to the hull , if people are intrested in this tecnique then il do the lay up as a tutorial
Dr4gonBones
#117 Posted : 24 February 2012 18:36:21
As long as you fill and sand the hull well, you shouldnt really need to coat the hull. if you want a smoother finish to it just brush on some watered down PVA and let it dry. Once primed you wouldn't notice a difference. All you really want to be doing is making sure you cant see the planking through the paint.
Has anyone thought of, or have any examples of weathering schemes for the akagi and yamato? Im not Sure whether to leave them as prime display models, or add some rust and evidence of battle damage from before their losses. LOL
Current Builds:
DeAgostini Akagi
DeAgostini Yamato
Dr4gonBones
#118 Posted : 24 February 2012 18:38:51
forgot to add:
Build is looking good by the way Andy. Just to add what i originally started replying to say LOL LOL
Current Builds:
DeAgostini Akagi
DeAgostini Yamato
#119 Posted : 24 February 2012 19:11:06
BigGrin Thanks Dragonbones for the nice comment, just to reply to your PVA method,yes that is an option but PVA like the acrylic paint you get now are all water based so the outer hull will not be compleatly sealed and still be affected by humidity factors which over time will crack the finish [especialy if as like most of us your running central heating].Hence my preferance to go for the epoxy finish on the outside and inside,also Tamiya do a weathering kit for IJN ships,look on my post in the Yamato model 'handrails and other goodies'.I think il just be going for the general weathering effect not any battle damage but thats quite an intresting idea
#120 Posted : 25 February 2012 13:37:00
Pack 7 arived this morning so cracked on with the build and assembled the stern framesCool,just a note here some of the facings to the 3 stern frames had marks/digs on them so just ensure that when you assemble them you have a good face on the top and bottom and double check the alignment as you clamp them up.As ussual all comments are welcome more pics to follow
Guest (7)
32 Pages «<45678>»
This page was generated in 0.270 seconds.
