 Rank: Amateur Level 1   Groups: Registered
Joined: 05/11/2009 Posts: 35 Points: 70 Location: New Zealand
jinks8 wrote:Thanks Hoover just waiting for admin to get back to me about some wood bits that wear not up to a usable standard and possible one part not sent tried to send him a PM but his in box was full hope to hear from him soon. If any one is trying to build this ship to sail sticking things on to a painted surface is not a good idea as the paint creates a week spot it has not got the strength as a metal glue metal contact as I have found out. Sum bit have to be glued on to paint it is unavoidable but keep it to as few pieces as possible hoop admin is not long in getting back to me  JJ Look for my "Attention Admin" post. I have been trying to PM him for well over a week now with no luck at all. Maybe if you through your weight in behind my request Admin will actually do something about his in box.
Joined: 24/01/2010 Posts: 131 Points: 398 Location: North Yorkshire FILEY By The Sea
Are the brass gun barrels part of the kit or are they aftermarket?
Part of the kit the quality of the metal bits so far is very good the small peaces could be better but at this scale it would be hard to get a lot of detail on to them
Joined: 11/09/2009 Posts: 44 Points: 98 Location: Liverpool
WOW, drilling out the windows is amaizing. I tried painting mine (see my build in same forum) and they look OK from a distance but pretty messy when you get close up. Don't know if Ive got time to drill them all out though. I dont have much spare time so need to keep going at a good pace.
It took a long time to do them that metel is !"!!! hard thanks just a waiting replacement bits so i can get on a bit moor jj
How many windows does one bit do?????
Just 2 but different sizes it was the needle files that were the problem kept braking the tips off them Had to bye a new set. Drill them out using the biggest drillTo fit windows I did it by hand you have more control that way the hard bit is filing to get them square as about 1/8in the file fit’s the hole to start whith so one twist to hard and snap alot off  but  and a big  in the end
Just sent Tomick a pm about the extra pieces he has got these are the bracing’s for the stern as we have not got them yet are we suppose to have them or do we get them later in the next part. GOOD TO HAVE THE BUILD UP AND RUNNING  JJ
Hi jinks8, you'll be receiving these parts in the next batches along with the start of the planking. I'm ploughing on with the Hull, and will then tackle the Superstructure etc, all coming together real nice so far, and just going to build as per the parts supplied and without any mods. Sounds like your going to have a real tasty model when your done, keep up the good work
thanks hope so good luck yours is looking good so far keep up the good work jj
just got this from De Agostini sent email around 2 or 3 weeks ago have sent relivent info so should hear back from them soon i hope
Thank you for your query. Please accept my sincere apologies for the delay in responding.
Can you please specify the part numbers that are either too thick or are missing? As soon as I have this information, I will be able to replace the parts for you.
Sincerely
Brigette Ford
Customer Care
The following question has been received:
Joined: 08/03/2010 Posts: 19 Points: 37 Location: Crawley, UK
Hi,
I have now recieved my first batch of parts for the Yamato and have a few questions.
I am assuming you didn't get the mettal gun and control tower with your first issue? As all I have for my first delivery is wooden parts in plastic bags? It says I have Yamato 01 and 02 so maybe the metal comes in 03 and 04?
Also how long after delivery did you get the email with the instructions in? Do you have to go and download it somewhere or something?
Hi AFK, you certainly should have metal parts in 1 & 2, and the instructions you should have received via email about the same time your parts arrived. I suggest you contact customer service or admin.
Hi Tomick,
After taking another look it seems as though I only got a package called DECI 0002 Yamato 2 which I assume is the second packet, so I am missing the first packet?? I will go check my post box tomorrow but it was the actual postman who dropped this packet off.
Does the first and second packets come seperately? Is there anywhere I can see what I should have recieved in my first delivery?
Thanks.
AFK_Matrix wrote:Hi,
Also how long after delivery did you get the email with the instructions in? Do you have to go and download it somewhere or something? If you got my em you will see the guns and tower came in the first part had em from DeAostini saying parts 3&4 will be posted this week that was on the 25 march so should be hear soon the em sort of got lost as it was to big for my in box but adini sorted it out got it in 3 difrent em hope this will help jj
Got mext build parts and started to build agane sum nice Etched brass bits for radar but still not got missing parts yet so had to start plankin from stern and no bow as per build. Got first 2 motors yester day will post pic,s assp
Still waiting for parts have bean promised them in 14 to 28 days hope they do come and are not to long
got this em from them ear: Mr Jenkinson Subject: Thank you for your correspondence. I wish to confirm that we have ordered replacements for the below, please be advised that we can’t replace the individual parts therefore the the issues will be replaced so that you may obtain the missing and damaged part. Kindly allow 14-28 days for delivery. Should you require further assistance, please do not hestitate to contact us directly. Kind Regards Sharlotte Botha Customer Care Consultant. Did you know you can view your account online? In addition to this, most of the questions you have regarding your account can be answered online. Follow the link to open up a new way of keeping in touch with your subscription. http://www.deagostini.co.uk/contact_us so it could be 10 MAY before i get the parts 14 to 28 days are the bits cumming from Italy parts 5/6 should be hear befor them
